Hi Kejuan - I’m glad you were able to answer your own questions so quickly
I’ll add these references to the GUI. Note that we try to display references as hover-over “tooltip” text as well as in the per-keyword help, but as you noted, not all options have a reference available.
What you list is not the correct reference for “Model A”. This terminology should be cited to the following:
J. X. Bouillard, R. W. Lyczkowski, S. Folga, D. Gidaspow and G. F. Berry, “Hydrodynamics of erosion of heat exchanger tubes in fluidized-bed combustors,” Canadian Journal of Chemical Engineering, vol. 67, p. 218–229, 1989.
