.vtu/.vtp output >4 GB unreadable — 64-bit offsets needed - Potential Fix for MFIX-26*
1. The issue.
On large cartesian-grid runs, .vtu/.vtp files became unreadable in ParaView once they crossed ~2 GB. The appended-data byte offsets (offset="…") and the per-block size prefixes were default 4-byte INTEGER, so they overflow at 2³¹. The files still wrote to full size, but the offset values wrapped to garbage and ParaView could no longer parse them.
2. Key modifications
(3 files: cartesian_grid/vtk_mod.f, cartesian_grid/vtk_out.f, des/vtp_mod.f):
  • VTU_offset and the per-routine nbytes_* / offset_* locals → INTEGER(KIND=8).
  • Byte-size products evaluated in 64-bit via INT(count,8), so the count×components term can’t overflow before promotion.
  • New module parameter VTK_HEADER_SIZE = 8: the appended-block size prefix grew 4→8 bytes, so every offset = prev + <prefix> + nbytes term now advances by 8 — not just the variable kinds (the bookkeeping point flagged on the channel).
  • header_type="UInt64" added to the <VTKFile> tags that carry appended data (UnstructuredGrid .vtu, PolyData .vtp); offset output field widened I12 → I20.
  • Used KIND=8 / c_int64_t throughout (8 bytes on both LP64 and LLP64), never c_long, so the 8-byte prefixes stay consistent with the existing byte_order="BigEndian", ACCESS='STREAM' writes on Windows and Linux. (One local literally named int was renamed int4 — it shadowed the INT() intrinsic.)
Payloads are unchanged (still Float32/Int32); files grow 4 bytes per appended block. Validated on HPC >3 GB .vtu files now write and open correctly in ParaView (When the default MFIX-25.3 or MFIX-26.1.1 did not). The fix was tested with some of the 2D TFM and DEM-CFD tutorials. Note Paraview 6.1.0 cannot open the files but Paraview 6.0* can :slight_smile: . The modified three subroutines are attached in the zip file.
vtk_mod.zip (48.3 KB)
Thanks Eric. We’ll do some testing and probably include your 64-bit patch in the next MFiX release (unscheduled at this time)
Re: the Paraview 6.1 issue:
Paraview doesn’t like the space character in front of the timestep value in the pvd file, they already have a fix for this (thanks for reporting the issue, it’s nice to see the open-source ecosystem working as intended):
vtkPVDReader: Fix parsing of values (!7827) · Merge requests · ParaView / ParaView · GitLab
We can also avoid creating the blank space on the MFiX side:
pvd_patch.txt (2.6 KB)
This will also be included in the next MFiX release.
