Wall Heat Flux output for 25.3
Could you please recommend a way to output wall heat flux for MFiX v25.3?
I’m a bit lost since there are seemingly 3 different approaches:
  1. Should I be getting that information from setting the wall as a Region, then Output→ VTK for it
  2. Or Monitor→ Geometry, Average → Heat transfer data?
  3. Attempt to set UDF’s to get wall heat flux similar to the DEM_Wall_HT tutorial that this other user tried with v24.4? Link: How to output heat flux for stl wall region in MFIX DEM for post-processing?
    Thank you!
