Hello researchers! I solved the energy equation while simulating particle fall, but the particle output file shows that the temperature is not read. Why is that? What do I need to do to display the temperature information for each particle? The relevant documents have been uploaded. Looking forward to hearing from you!
1mm-energy-luokeli.zip (31.7 MB)
Examining the code in read_particle_input.f
! Temperature option
IF(ENERGY_EQ) THEN
call check_if_uniform(des_t_s,is_uniform, Uniform_Temperature)
IF(is_uniform) THEN
write(Temperature_setting,'(A,F14.8)') 'Temperature: F ', Uniform_Temperature
Temperature_start = -1
ELSE
column_header = trim(column_header)//" Temperature |"
Temperature_setting = 'temperature: T'
Temperature_start = n_vars + 1
n_vars = n_vars + 1
ENDIF
ELSE
Temperature_setting = 'Temperature: T (Ignored if energy eq. is not solved)'
ENDIF
it appears that in your case, the particle temperatures are uniform (there is no fluid phase, this is pure granular flow, with no reactions, what would change the particle temperatures?) - looking at the particles with VTK they are all 293.15K
Furthermore I added a line:
write(*,*) "is_uniform", is_uniform, "T=", Uniform_Temperature
and you can see the is_uniform T
in the output window.
If the particle temperatures were non-uniform, they would be written out per-particle.
