Configure CodeClimate-based Code Quality scanning (deprecated)
DETAILS: Tier: Free, Premium, Ultimate Offering: GitLab.com, Self-managed, GitLab Dedicated
WARNING: This feature was deprecated in GitLab 17.3 and is planned for removal in 18.0. Integrate the results from a supported tool directly instead. This change is a breaking change.
Code Quality includes a built-in CI/CD template, Code-Quality.gitlab-ci.yaml
This template runs a scan based on the open source CodeClimate scanning engine.
The CodeClimate engine runs:
- Basic maintainability checks for a set of supported languages.
- A configurable set of plugins, which wrap open source scanners, to analyze your source code.
Enable CodeClimate-based scanning
Prerequisites:
- GitLab CI/CD configuration (
.gitlab-ci.yml
) must include thetest
stage. - If you're using instance runners, the Code Quality job must be configured for the
Docker-in-Docker workflow.
When using this workflow, the
/builds
volume must be mapped to allow reports to be saved. - If you're using private runners, you should use an alternative configuration recommended for running Code Quality analysis more efficiently.
- The runner must have enough disk space to store the generated Code Quality files. For example, on the GitLab project the files are approximately 7 GB.
To enable Code Quality, either:
Enable Auto DevOps, which includes Auto Code Quality.
Include the Code Quality template in your
.gitlab-ci.yml
file.Example:
include: - template: Jobs/Code-Quality.gitlab-ci.yml
Code Quality now runs in pipelines.
WARNING: On self-managed instances, if a malicious actor compromises the Code Quality job definition they could execute privileged Docker commands on the runner host. Having proper access control policies mitigates this attack vector by allowing access only to trusted actors.
Disable CodeClimate-based scanning
The code_quality
job doesn't run if the $CODE_QUALITY_DISABLED
CI/CD variable
is present. For more information about how to define a variable, see
GitLab CI/CD variables.
To disable Code Quality, create a custom CI/CD variable named CODE_QUALITY_DISABLED
, for either:
Configure CodeClimate analysis plugins
By default, the code_quality
job configures CodeClimate to:
- Use a specific set of plugins.
- Use default configurations for those plugins.
To scan more languages, you can enable more plugins.
You can also disable plugins that the code_quality
job enables by default.
For example, to use the SonarJava analyzer:
Add a file named
.codeclimate.yml
to the root of your repository -
Add the enablement code for the plugin to the root of your repository to the
.codeclimate.yml
file:version: "2" plugins: sonar-java: enabled: true
This adds SonarJava to the plugins:
section of the
default .codeclimate.yml
included in your project.
Changes to the plugins:
section do not affect the exclude_patterns
section of the default
.codeclimate.yml
. See the Code Climate documentation on
excluding files and folders
for more details.
Customize scan job settings
You can change the behavior of the code_quality
scan job by setting CI/CD variables in your GitLab CI/CD YAML.
To configure the Code Quality job:
- Declare a job with the same name as the Code Quality job, after the template's inclusion.
- Specify additional keys in the job's stanza.
For an example, see Download output in HTML format.
Available CI/CD variables
Code Quality can be customized by defining available CI/CD variables:
CI/CD variable | Description |
CODECLIMATE_DEBUG |
Set to enable Code Climate debug mode. |
CODECLIMATE_DEV |
Set to enable --dev mode which lets you run engines not known to the CLI. |
CODECLIMATE_PREFIX |
Set a prefix to use with all docker pull commands in CodeClimate engines. Useful for offline scanning. For more information, see Use a private container registry. |
CODECLIMATE_REGISTRY_USERNAME |
Set to specify the username for the registry domain parsed from CODECLIMATE_PREFIX . |
CODECLIMATE_REGISTRY_PASSWORD |
Set to specify the password for the registry domain parsed from CODECLIMATE_PREFIX . |
CODE_QUALITY_DISABLED |
Prevents the Code Quality job from running. |
CODE_QUALITY_IMAGE |
Set to a fully prefixed image name. Image must be accessible from your job environment. |
ENGINE_MEMORY_LIMIT_BYTES |
Set the memory limit for engines. Default: 1,024,000,000 bytes. |
REPORT_STDOUT |
Set to print the report to STDOUT instead of generating the usual report file. |
REPORT_FORMAT |
Set to control the format of the generated report file. Either json or html . |
SOURCE_CODE |
Path to the source code to scan. Must be the absolute path to a directory where cloned sources are stored. |
TIMEOUT_SECONDS |
Custom timeout per engine container for the codeclimate analyze command. Default: 900 seconds (15 minutes) |
Output
Code Quality outputs a report containing details of issues found. The content of this report is
processed internally and the results shown in the UI. The report is also output as a job artifact of
the code_quality
job, named gl-code-quality-report.json
. You can optionally output the report in
HTML format. For example, you could publish the HTML format file on GitLab Pages for even easier
reviewing.
Output in JSON and HTML format
To output the Code Quality report in JSON and HTML format, you create an additional job. This requires Code Quality to be run twice, once each for file format.
To output the Code Quality report in HTML format, add another job to your template by using
extends: code_quality
include:
code_quality_html:
variables:
REPORT_FORMAT: html
artifacts:
paths: [gl-code-quality-report.html]
Both the JSON and HTML files are output as job artifacts. The HTML file is contained in the
artifacts.zip
job artifact.
Output in only HTML format
To download the Code Quality report in only HTML format, set REPORT_FORMAT
to html
, overriding
the default definition of the code_quality
job.
NOTE: This does not create a JSON format file, so Code Quality results are not shown in the merge request widget, pipeline report, or changes view.
include:
code_quality:
variables:
REPORT_FORMAT: html
artifacts:
The HTML file is output as a job artifact.
Use Code Quality with merge request pipelines
The default Code Quality configuration does not allow the code_quality
job to run on
merge request pipelines.
To enable Code Quality to run on merge request pipelines, overwrite the code quality rules
or workflow: rules
, so that they match your current rules
For example:
include:
code_quality:
rules:
- if: $CODE_QUALITY_DISABLED
when: never
- if: $CI_PIPELINE_SOURCE == "merge_request_event" # Run code quality job in merge request pipelines
- if: $CI_COMMIT_BRANCH == $CI_DEFAULT_BRANCH # Run code quality job in pipelines on the default branch (but not in other branch pipelines)
- if: $CI_COMMIT_TAG # Run code quality job in pipelines for tags
Change how CodeClimate images are downloaded
The CodeClimate engine downloads container images to run each of its plugins. By default, the images are downloaded from Docker Hub. You can change the image source to improve performance, work around Docker Hub rate limits, or use a private registry.
Use the Dependency Proxy to download images
You can use a Dependency Proxy to reduce the time taken to download dependencies.
Prerequisites:
- Dependency Proxy enabled in the project's group.
To reference the Dependency Proxy, configure the following variables in the .gitlab-ci.yml
file:
CODE_QUALITY_IMAGE
CODECLIMATE_PREFIX
For example:
include:
code_quality:
variables:
## You must add a trailing slash to `$CI_DEPENDENCY_PROXY_GROUP_IMAGE_PREFIX`.
CODECLIMATE_PREFIX: $CI_DEPENDENCY_PROXY_GROUP_IMAGE_PREFIX/
CODECLIMATE_REGISTRY_USERNAME: $CI_DEPENDENCY_PROXY_USER
CODECLIMATE_REGISTRY_PASSWORD: $CI_DEPENDENCY_PROXY_PASSWORD
Use Docker Hub with authentication
You can use Docker Hub as an alternate source of the Code Quality images.
Prerequisites:
- Add the username and password as protected CI/CD variables in the project.
To use DockerHub, configure the following variables in the .gitlab-ci.yml
file:
CODECLIMATE_PREFIX
Example:
include:
code_quality:
variables:
CODECLIMATE_PREFIX: "registry-1.docker.io/"
CODECLIMATE_REGISTRY_USERNAME: $DOCKERHUB_USERNAME
CODECLIMATE_REGISTRY_PASSWORD: $DOCKERHUB_PASSWORD
Use a private container image registry
Using a private container image registry can reduce the time taken to download images, and also
reduce external dependencies. You must configure the registry prefix to be passed down
to CodeClimate's subsequent docker pull
commands for individual engines, because of
the nested method of container execution.
The following variables can address all of the required image pulls:
CODE_QUALITY_IMAGE
: A fully prefixed image name that can be located anywhere accessible from your job environment. GitLab container registry can be used here to host your own copy. -
CODECLIMATE_PREFIX
: The domain of your intended container image registry. This is a configuration option supported by CodeClimate CLI. You must:- Include a trailing slash (
). - Not include a protocol prefix, such as
https://
: An optional variable to specify the username for the registry domain parsed fromCODECLIMATE_PREFIX
: An optional variable to specify the password for the registry domain parsed fromCODECLIMATE_PREFIX
include:
code_quality:
variables:
CODE_QUALITY_IMAGE: "my-private-registry.local:12345/codequality:0.85.24"
CODECLIMATE_PREFIX: "my-private-registry.local:12345/"
This example is specific to GitLab Code Quality. For more general instructions on how to configure DinD with a registry mirror, see Enable registry mirror for Docker-in-Docker service.
Required images
The following images are required for the default .codeclimate.yml
codeclimate/codeclimate-structure:latest
codeclimate/codeclimate-csslint:latest
codeclimate/codeclimate-coffeelint:latest
codeclimate/codeclimate-duplication:latest
codeclimate/codeclimate-eslint:latest
codeclimate/codeclimate-fixme:latest
codeclimate/codeclimate-rubocop:rubocop-0-92
If you are using a custom .codeclimate.yml
configuration file, you must add the specified plugins in your private container registry.
Change Runner configuration
CodeClimate runs separate containers for each of its analysis steps. You may need to adjust your Runner configuration so that CodeClimate-based scans can run, or so that they run faster.
Use private runners
If you have private runners, you should use this configuration for improved performance of Code Quality because:
- Privileged mode is not used.
- Docker-in-Docker is not used.
- Docker images, including all CodeClimate images, are cached, and not re-fetched for subsequent jobs.
This alternative configuration uses socket binding to share the Runner's Docker daemon with the job environment. Before implementing this configuration, consider its limitations.
To use private runners:
Register a new runner:
$ gitlab-runner register --executor "docker" \ --docker-image="docker:latest" \ --url "https://gitlab.com/" \ --description "cq-sans-dind" \ --docker-volumes "/cache"\ --docker-volumes "/builds:/builds"\ --docker-volumes "/var/run/docker.sock:/var/run/docker.sock" \ --registration-token="<project_token>" \ --non-interactive
Optional, but recommended: Set the builds directory to
/tmp/builds
, so job artifacts are periodically purged from the runner host. If you skip this step, you must clean up the default builds directory (/builds
) yourself. You can do this by adding the following two flags togitlab-runner register
in the previous step.--builds-dir "/tmp/builds" --docker-volumes "/tmp/builds:/tmp/builds" # Use this instead of --docker-volumes "/builds:/builds"
The resulting configuration:
[[runners]] name = "cq-sans-dind" url = "https://gitlab.com/" token = "<project_token>" executor = "docker" builds_dir = "/tmp/builds" [runners.docker] tls_verify = false image = "docker:latest" privileged = false disable_entrypoint_overwrite = false oom_kill_disable = false disable_cache = false volumes = ["/cache", "/var/run/docker.sock:/var/run/docker.sock", "/tmp/builds:/tmp/builds"] shm_size = 0 [runners.cache] [runners.cache.s3] [runners.cache.gcs]
Apply two overrides to the
code_quality
job created by the template:include: - template: Jobs/Code-Quality.gitlab-ci.yml code_quality: services: # Shut off Docker-in-Docker tags: - cq-sans-dind # Set this job to only run on our new specialized runner
Code Quality now runs in standard Docker mode.
Run CodeClimate rootless with private runners
If you are using private runners and would like to run the Code Quality scans in rootless Docker mode code quality requires some special changes to allow it to run properly. This may require having a runner dedicated to running only code quality jobs because changes in socket binding may cause problems in other jobs.
To use a rootless private runner:
Replace
/run/user/<gitlab-runner-user>/docker.sock
with the path to the localdocker.sock
for thegitlab-runner
user.$ gitlab-runner register --executor "docker" \ --docker-image="docker:latest" \ --url "https://gitlab.com/" \ --description "cq-rootless" \ --tag-list "cq-rootless" \ --locked="false" \ --access-level="not_protected" \ --docker-volumes "/cache" \ --docker-volumes "/tmp/builds:/tmp/builds" \ --docker-volumes "/run/user/<gitlab-runner-user>/docker.sock:/run/user/<gitlab-runner-user>/docker.sock" \ --token "<project_token>" \ --non-interactive \ --builds-dir "/tmp/builds" \ --env "DOCKER_HOST=unix:///run/user/<gitlab-runner-user>/docker.sock" \ --docker-host "unix:///run/user/<gitlab-runner-user>/docker.sock"
[[runners]] name = "cq-rootless" url = "https://gitlab.com/" token = "<project_token>" executor = "docker" builds_dir = "/tmp/builds" environment = ["DOCKER_HOST=unix:///run/user/<gitlab-runner-user>/docker.sock"] [runners.docker] tls_verify = false image = "docker:latest" privileged = false disable_entrypoint_overwrite = false oom_kill_disable = false disable_cache = false volumes = ["/cache", "/run/user/<gitlab-runner-user>/docker.sock:/run/user/<gitlab-runner-user>/docker.sock", "/tmp/builds:/tmp/builds"] shm_size = 0 host = "unix:///run/user/<gitlab-runner-user>/docker.sock" [runners.cache] [runners.cache.s3] [runners.cache.gcs]
Apply the following overrides to the
code_quality
job created by the template:code_quality: services: variables: DOCKER_SOCKET_PATH: /run/user/997/docker.sock tags: - cq-rootless
Code Quality now runs in standard Docker mode and rootless.
The same configuration is required if your goal is to use rootless Podman to run Docker with code quality. Make sure to replace /run/user/<gitlab-runner-user>/docker.sock
with the correct podman.sock
path in your system, for example: /run/user/<gitlab-runner-user>/podman/podman.sock
Configure Kubernetes or OpenShift runners
You must set up Docker in a Docker container (Docker-in-Docker) to use Code Quality. The Kubernetes executor supports Docker-in-Docker.
To ensure Code Quality jobs can run on a Kubernetes executor:
- If you're using TLS to communicate with the Docker daemon, the executor must be running in privileged mode. Additionally, the certificate directory must be specified as a volume mount.
- It is possible that the DinD service doesn't start up fully before the Code Quality job starts. This is a limitation documented in
Troubleshooting the Kubernetes executor. To resolve the issue, use
before_script
to wait for the Docker daemon to fully boot up. For an example, see the configuration in the.gitlab-ci.yml
file below.
Kubernetes
To run Code Quality in Kubernetes:
- The Docker in Docker service must be added as a service container in the
config.toml
file. - The Docker daemon in the service container must listen on a TCP and UNIX socket, as both sockets are required by Code Quality.
- The Docker socket must be shared with a volume.
Due to a Docker requirement, the privileged flag must be enabled for the service container.
[runners.kubernetes]
[runners.kubernetes.service_container_security_context]
privileged = true
allow_privilege_escalation = true
[runners.kubernetes.volumes]
[[runners.kubernetes.volumes.empty_dir]]
mount_path = "/var/run/"
name = "docker-sock"
[[runners.kubernetes.services]]
alias = "dind"
command = [
"--host=tcp://0.0.0.0:2375",
"--host=unix://var/run/docker.sock",
"--storage-driver=overlay2"
entrypoint = ["dockerd"]
name = "docker:20.10.12-dind"
NOTE:
If you use the GitLab Runner Helm Chart, you can use
the above Kubernetes configuration in the config
in the values.yaml
file.
To ensure that you use the overlay2
storage driver, which offers the best overall performance:
- Specify the
DOCKER_HOST
that the Docker CLI communicates with. - Set the
DOCKER_DRIVER
variable to empty.
Use the before_script
section to wait for the Docker daemon to fully boot up. Since GitLab Runner v16.9, this can also be done by just setting the HEALTHCHECK_TCP_PORT
variable.
include:
- template: Code-Quality.gitlab-ci.yml
code_quality:
services: []
variables:
DOCKER_HOST: tcp://dind:2375
DOCKER_DRIVER: ""
before_script:
- while ! docker info > /dev/null 2>&1; do sleep 1; done
OpenShift
For OpenShift, you should use the GitLab Runner Operator.
To give the Docker daemon in the service container permissions to initialize its storage,
you must mount the /var/lib
directory as a volume mount.
NOTE:
If you cannot to mount the /var/lib
directory as a volume mount, you can set --storage-driver
to vfs
instead.
If you opt for the vfs
value, it might have a negative
impact on performance.
To configure permissions for the Docker daemon,
- Create a file called
config.toml
with the configuration provided below. This configuration will be used to customized GitLab Runner generatedconfig.toml
[[runners]]
privileged = true
mount_path = "/var/lib/"
name = "docker-data"
alias = "dind"
command = [
Optional. Attach a
privileged
service account to the build Pod. This depends on your OpenShift cluster setup:oc create sa dind-sa oc adm policy add-scc-to-user anyuid -z dind-sa oc adm policy add-scc-to-user -z dind-sa privileged
Set the permissions in the
section. -
Set the job definition stays the same as in Kubernetes case:
include: - template: Code-Quality.gitlab-ci.yml code_quality: services: [] variables: DOCKER_HOST: tcp://dind:2375 DOCKER_DRIVER: "" before_script: - while ! docker info > /dev/null 2>&1; do sleep 1; done
Volumes and Docker storage
Docker stores all of its data in the /var/lib
volume, which could result in a large volume. To reuse Docker-in-Docker storage across the cluster,
you can use Persistent Volumes as an alternative.
