AI features based on 3rd-party integrations
Instructions for setting up GitLab Duo features in the local development environment
Required: Install AI Gateway
Why: All Duo features route LLM requests through the AI Gateway.
How: Follow these instructions to install the AI Gateway with GDK. We recommend this route for most users.
You can also install AI Gateway by:
We only recommend this for users who have a specific reason for not running the AI Gateway through GDK.
Required: Setup Licenses in GitLab-Rails
Why: GitLab Duo is available to Premium and Ultimate customers only. You likely want an Ultimate license for your GDK. Ultimate gets you access to all GitLab Duo features.
How:
Follow the process to obtain an EE license for your local instance and upload the license.
To verify that the license is applied, go to Admin area > Subscription and check the subscription plan.
Set up and run GDK
Option A: in SaaS (GitLab.com) Mode
Why: Most Duo features are available on GitLab.com first, so running in SaaS mode will ensure that you can access most features.
How:
Run the Rake task to set up Duo features for a group:
GITLAB_SIMULATE_SAAS=1 bundle exec 'rake gitlab:duo:setup[test-group-name]'
gdk restart
Replace test-group-name
with the name of any top-level group. Duo will
be configured for that group. If the group doesn't exist, it creates a new
one.
Make sure the script succeeds. It prints error messages with links on how to resolve any errors. You can re-run the script until it succeeds.
In SaaS mode, membership to a group with Duo features enabled is what enables
many AI features. Make sure that your test user is a member of the group with
Duo features enabled (test-group-name
Option B: in Self-managed Mode
Why: If you want to test something specific to self-managed, such as Custom Models.
How:
Run the Rake task to set up Duo features for the instance:
GITLAB_SIMULATE_SAAS=0 bundle exec 'rake gitlab:duo:setup'
gdk restart
CLOUD_CONNECTOR_SELF_SIGN_TOKENS
environment variable
Recommended: Set Why: Setting this environment variable will allow the local GitLab instance to issue tokens itself, without syncing with CustomersDot first. With this set, you can skip the CustomersDot setup.
How: The following should be set in the env.runit
file in your GDK root:
# <GDK-root>/env.runit
export CLOUD_CONNECTOR_SELF_SIGN_TOKENS=1
You need to restart GDK to apply the change.
If you use CLOUD_CONNECTOR_SELF_SIGN_TOKENS=1
, th root
/admin
user must
have a seat assigned
to receive a "Code completion test was successful" notification from the health check
on the http://localhost:3000/admin/code_suggestions
page.
Our customers (production environment) do not need to do that to run a Code Suggestions health check.
Recommended: Test clients in Rails console
Why: you've completed all of the setup steps, now it's time to confirm that GitLab Duo is actually working.
How:
After the setup is complete, you can test clients in GitLab-Rails to see if it can correctly reach to AI Gateway:
Run
gdk start
Login to Rails console with
gdk rails console
Talk to a model:
# Talk to Anthropic model Gitlab::Llm::Anthropic::Client.new(User.first, unit_primitive: 'duo_chat').complete(prompt: "\n\nHuman: Hi, How are you?\n\nAssistant:") # Talk to Vertex AI model Gitlab::Llm::VertexAi::Client.new(User.first, unit_primitive: 'documentation_search').text_embeddings(content: "How can I create an issue?") # Test `/v1/chat/agent` endpoint Gitlab::Llm::Chain::Requests::AiGateway.new(User.first).request(prompt: [{role: "user", content: "Hi, how are you?"}])
NOTE: See this doc for registering unit primitives in Cloud Connector.
Optional: Enable authentication and authorization in AI Gateway
Why: The AI Gateway has authentication and authorization flow to verify if clients have permission to access the features. Auth is enforced in any live environments hosted by GitLab infra team. You may want to test this flow in your local development environment.
NOTE: In development environments (for example: GDK), this process is disabled by default.
To enable authorization checks, set AIGW_AUTH__BYPASS_EXTERNAL
to false
in the
application setting file
(<GDK-root>/gitlab-ai-gateway/.env
) in AI Gateway.
Option 1: Use your GitLab instance as a provider
Why: this is the simplest method of testing authentication and reflects our setup on GitLab.com.
How: Assuming that you are running the AI Gateway with GDK, apply the following configuration to GDK:
export GITLAB_SIMULATE_SAAS=1
Update the application settings file in AI Gateway:
# <GDK-root>/gitlab-ai-gateway/.env
AIGW_AUTH__BYPASS_EXTERNAL=false
AIGW_GITLAB_URL=<your-gdk-url>
and gdk restart
Option 2: Use your customersDot instance as a provider
Why: CustomersDot setup is required when you want to test or update functionality related to cloud licensing or if you are running GDK in non-SaaS mode.
NOTE: This setup is challenging. There is an issue for discussing how to make it easier to test the customersDot integration locally. Until that is addressed, this setup process is time consuming and should be avoided if possible.
If you need to get customersDot working for your local GitLab Rails instance for
any reason, reach out to #s_fulfillment_engineering
in Slack. For questions around the integration of CDot with other systems to deliver AI use cases, reach out to #g_cloud_connector
assistance.
Help
- Here's how to reach us!
- View guidelines for working with GitLab Duo Chat.
Tips for local development
- When responses are taking too long to appear in the user interface, consider
restarting Sidekiq by running
gdk restart rails-background-jobs
. If that doesn't work, trygdk kill
and thengdk start
. - Alternatively, bypass Sidekiq entirely and run the service synchronously.
This can help with debugging errors as GraphQL errors are now available in
the network inspector instead of the Sidekiq logs. To do that, temporarily alter
the
perform_for
method inLlm::CompletionWorker
class by changingperform_async
toperform_inline
Feature development (Abstraction Layer)
Feature flags
Apply the following feature flags to any AI feature work:
- A general flag (
ai_duo_chat_switch
) that applies to all GitLab Duo Chat features. It's enabled by default. - A general flag (
ai_global_switch
) that applies to all other AI features. It's enabled by default. - A flag specific to that feature. The feature flag name must be different than the licensed feature name.
See the feature flag tracker epic for the list of all feature flags and how to use them.
Push feature flags to AI Gateway
You can push feature flags to AI Gateway. This is helpful to gradually rollout user-facing changes even if the feature resides in AI Gateway. See the following example:
# Push a feature flag state to AI Gateway.
Gitlab::AiGateway.push_feature_flag(:new_prompt_template, user)
Later, you can use the feature flag state in AI Gateway in the following way:
from ai_gateway.feature_flags import is_feature_enabled
# Check if the feature flag "new_prompt_template" is enabled.
if is_feature_enabled('new_prompt_template'):
# Build a prompt from the new prompt template
else:
# Build a prompt from the old prompt template
IMPORTANT: At the cleaning up step, remove the feature flag in AI Gateway repository before removing the flag in GitLab-Rails repository. If you clean up the flag in GitLab-Rails repository at first, the feature flag in AI Gateway will be disabled immediately as it's the default state, hence you might encounter a surprising behavior.
IMPORTANT: Cleaning up the feature flag in AI Gateway will immediately distribute the change to all GitLab instances, including GitLab.com, Self-managed GitLab, and Dedicated.
Technical details: When push_feature_flag
runs on an enabled feature flag, the name of flag is cached in the current context,
which is later attached to x-gitlab-enabled-feature-flags
HTTP header when GitLab-Sidekiq/Rails requests to AI Gateway.
As a simialr concept, we also have push_frontend_feature_flag
to push feature flags to frontend.
GraphQL API
To connect to the AI provider API using the Abstraction Layer, use an extendable
GraphQL API called aiAction
The input
accepts key/value pairs, where the key
is the action that needs to
be performed. We only allow one AI action per mutation request.
Example of a mutation:
mutation {
aiAction(input: {summarizeComments: {resourceId: "gid://gitlab/Issue/52"}}) {
clientMutationId
As an example, assume we want to build an "explain code" action. To do this, we extend the input
with a new key,
explainCode
. The mutation would look like this:
mutation {
aiAction(
input: {
explainCode: { resourceId: "gid://gitlab/MergeRequest/52", code: "foo() { console.log() }" }
clientMutationId
The GraphQL API then uses the Anthropic Client to send the response.
How to receive a response
The API requests to AI providers are handled in a background job. We therefore do not keep the request alive and the Frontend needs to match the request to the response from the subscription.
WARNING:
Determining the right response to a request can cause problems when only userId
and resourceId
are used. For example, when two AI features use the same userId
and resourceId
both subscriptions will receive the response from each other. To prevent this interference, we introduced the clientSubscriptionId
To match a response on the aiCompletionResponse
subscription, you can provide a clientSubscriptionId
to the aiAction
mutation.
- The
should be unique per feature and within a page to not interfere with other AI features. We recommend to use aUUID
. - Only when the
is provided as part of theaiAction
mutation, it will be used for broadcasting theaiCompletionResponse
. - If the
is not provided, onlyuserId
andresourceId
are used for theaiCompletionResponse
As an example mutation for summarizing comments, we provide a randomId
as part of the mutation:
mutation {
aiAction(
input: {
summarizeComments: { resourceId: "gid://gitlab/Issue/52" }
clientSubscriptionId: "randomId"
clientMutationId
In our component, we then listen on the aiCompletionResponse
using the userId
, resourceId
and clientSubscriptionId
("randomId"
subscription aiCompletionResponse(
$userId: UserID
$resourceId: AiModelID
$clientSubscriptionId: String
userId: $userId
resourceId: $resourceId
clientSubscriptionId: $clientSubscriptionId
content
errors
The subscription for Chat behaves differently.
To not have many concurrent subscriptions, you should also only subscribe to the subscription once the mutation is sent by using skip()
Current abstraction layer flow
The following graph uses VertexAI as an example. You can use different providers.
flowchart TD
A[GitLab frontend] -->B[AiAction GraphQL mutation]
B --> C[Llm::ExecuteMethodService]
C --> D[One of services, for example: Llm::GenerateSummaryService]
D -->|scheduled| E[AI worker:Llm::CompletionWorker]
E -->F[::Gitlab::Llm::Completions::Factory]
F -->G[`::Gitlab::Llm::VertexAi::Completions::...` class using `::Gitlab::Llm::Templates::...` class]
G -->|calling| H[Gitlab::Llm::VertexAi::Client]
H --> |response| I[::Gitlab::Llm::GraphqlSubscriptionResponseService]
I --> J[GraphqlTriggers.ai_completion_response]
J --> K[::GitlabSchema.subscriptions.trigger]
How to implement a new action
Implementing a new AI action will require changes in the GitLab monolith as well as in the AI Gateway. We'll use the example of wanting to implement an action that allows users to rewrite issue descriptions according to a given prompt.
1. Add your action to the Cloud Connector feature list
The Cloud Connector configuration stores the permissions needed to access your service, as well as additional metadata. For more information, see Cloud Connector: Configuration.
# ee/config/cloud_connector/access_data.yml
services:
rewrite_description:
backend: 'gitlab-ai-gateway'
bundled_with:
duo_enterprise:
unit_primitives:
- rewrite_issue_description
2. Create an Agent definition in the AI Gateway
In the AI Gateway project, create a
new agent definition under ai_gateway/agents/definitions
. Create a new subfolder corresponding to the name of your
AI action, and a new YAML file for your agent. Specify the model and provider you wish to use, and the prompts that
will be fed to the model. You can specify inputs to be plugged into the prompt by using {}
# ai_gateway/agents/definitions/rewrite_description/base.yml
model:
params:
model_class_provider: anthropic
prompt_template:
system: |
You are a helpful assistant that rewrites the description of resources. You'll be given the current description, and a prompt on how you should rewrite it. Reply only with your rewritten description.
<description>{description}</description>
<prompt>{prompt}</prompt>
If your AI action is part of a broader feature, the definitions can be organized in a tree structure:
# ai_gateway/agents/definitions/code_suggestions/generations/base.yml
name: Code generations
model:
params:
To specify prompts for multiple models, use the name of the model as the filename for the definition:
# ai_gateway/agents/definitions/code_suggestions/generations/mistral.yml
model:
params:
model_class_provider: litellm
3. Create a Completion class
- Create a new completion under
ee/lib/gitlab/llm/ai_gateway/completions/
and inherit it from theBase
AI Gateway Completion.
# ee/lib/gitlab/llm/ai_gateway/completions/rewrite_description.rb
module Gitlab
module Llm
module AiGateway
module Completions
class RewriteDescription < Base
def agent_name
'base' # Must match the name of the agent you defined on the AI Gateway
end
def inputs
{ description: resource.description, prompt: prompt_message.content }
end
end
end
end
end
end
4. Create a Service
- Create a new service under
ee/app/services/llm/
and inherit it from theBaseService
. - The
resource
is the object we want to act on. It can be any object that includes theAi::Model
concern. For example it could be aProject
,MergeRequest
, orIssue
# ee/app/services/llm/rewrite_description_service.rb
module Llm
class RewriteDescriptionService < BaseService
extend ::Gitlab::Utils::Override
override :valid
def valid?
super &&
# You can restrict which type of resources your service applies to
resource.to_ability_name == "issue" &&
# Always check that the user is allowed to perform this action on the resource
Ability.allowed?(user, :rewrite_description, resource)
end
private
def perform
schedule_completion_worker
end
end
end
5. Register the feature in the catalogue
Go to Gitlab::Llm::Utils::AiFeaturesCatalogue
and add a new entry for your AI action.
class AiFeaturesCatalogue
LIST = {
rewrite_description: {
service_class: ::Gitlab::Llm::AiGateway::Completions::RewriteDescription,
feature_category: :ai_abstraction_layer,
execute_method: ::Llm::RewriteDescriptionService,
maturity: :experimental,
self_managed: false,
internal: false
}.freeze
How to migrate an existing action to the AI Gateway
AI actions were initially implemented inside the GitLab monolith. As part of our AI Gateway as the Sole Access Point for Monolith to Access Models Epic we're migrating prompts, model selection and model parameters into the AI Gateway. This will increase the speed at which we can deliver improvements to self-managed users, by decoupling prompt and model changes from monolith releases. To migrate an existing action:
- Follow steps 1 through 3 on How to implement a new action.
- Modify the entry for your AI action in the catalogue to list the new completion class as the
aigw_service_class
LIST = {
generate_description: {
service_class: ::Gitlab::Llm::Anthropic::Completions::GenerateDescription,
aigw_service_class: ::Gitlab::Llm::AiGateway::Completions::GenerateDescription,
prompt_class: ::Gitlab::Llm::Templates::GenerateDescription,
execute_method: ::Llm::GenerateDescriptionService,
internal: false
}.freeze
When the feature flag ai_gateway_agents
is enabled, the aigw_service_class
will be used to process the AI action.
Once you've validated the correct functioning of your action, you can remove the aigw_service_class
key and replace
the service_class
with the new AiGateway::Completions
class to make it the permanent provider.
For a complete example of the changes needed to migrate an AI action, see the following MRs:
Authorization in GitLab-Rails
We recommend to use policies to deal with authorization for a feature. Currently we need to make sure to cover the following checks:
Some basic authorization is included in the Abstraction Layer classes that are base classes for more specialized classes.
What needs to be included in the code:
- Check for feature flag compatibility:
Gitlab::Llm::Utils::FlagChecker.flag_enabled_for_feature?(ai_action)
- included in theLlm::BaseService
class. - Check if resource is authorized:
Gitlab::Llm::Utils::Authorizer.resource(resource: resource, user: user).allowed?
- also included in theLlm::BaseService
class. - Both of those checks are included in the
::Gitlab::Llm::FeatureAuthorizer.new(container: subject_container, feature_name: action_name).allowed?
- Access to AI features depend on several factors, such as: their maturity, if they are enabled on self-managed, if they are bundled within an add-on etc.
NOTE: For more information, see the GitLab AI Gateway documentation about authentication and authorization in AI Gateway.
Pairing requests with responses
Because multiple users' requests can be processed in parallel, when receiving responses,
it can be difficult to pair a response with its original request. The requestId
field can be used for this purpose, because both the request and response are assured
to have the same requestId
UUID.
Caching
AI requests and responses can be cached. Cached conversation is being used to display user interaction with AI features. In the current implementation, this cache is not used to skip consecutive calls to the AI service when a user repeats their requests.
query {
aiMessages {
nodes {
id
requestId
content
role
errors
timestamp
This cache is used for chat functionality. For other services, caching is
disabled. You can enable this for a service by using the cache_response: true
option.
Caching has following limitations:
- Messages are stored in Redis stream.
- There is a single stream of messages per user. This means that all services currently share the same cache. If needed, this could be extended to multiple streams per user (after checking with the infrastructure team that Redis can handle the estimated amount of messages).
- Only the last 50 messages (requests + responses) are kept.
- Expiration time of the stream is 3 days since adding last message.
- User can access only their own messages. There is no authorization on the caching level, and any authorization (if accessed by not current user) is expected on the service layer.
Check if feature is allowed for this resource based on namespace settings
There is one setting allowed on root namespace level that restrict the use of AI features:
experiment_features_enabled
To check if that feature is allowed for a given namespace, call:
Gitlab::Llm::StageCheck.available?(namespace, :name_of_the_feature)
Add the name of the feature to the Gitlab::Llm::StageCheck
class. There are
arrays there that differentiate between experimental and beta features.
This way we are ready for the following different cases:
- If the feature is not in any array, the check will return
true
. For example, the feature was moved to GA.
To move the feature from the experimental phase to the beta phase, move the name of the feature from the EXPERIMENTAL_FEATURES
array to the BETA_FEATURES
array.
Implement calls to AI APIs and the prompts
The CompletionWorker
will call the Completions::Factory
which will initialize the Service and execute the actual call to the API.
In our example, we will use VertexAI and implement two new classes:
# /ee/lib/gitlab/llm/vertex_ai/completions/rewrite_description.rb
module Gitlab
module Llm
module VertexAi
module Completions
class AmazingNewAiFeature < Gitlab::Llm::Completions::Base
def execute
prompt = ai_prompt_class.new(options[:user_input]).to_prompt
response = Gitlab::Llm::VertexAi::Client.new(user, unit_primitive: 'amazing_feature').text(content: prompt)
response_modifier = ::Gitlab::Llm::VertexAi::ResponseModifiers::Predictions.new(response)
::Gitlab::Llm::GraphqlSubscriptionResponseService.new(
user, nil, response_modifier, options: response_options
).execute
end
end
end
end
end
end
# /ee/lib/gitlab/llm/vertex_ai/templates/rewrite_description.rb
module Gitlab
module Llm
module VertexAi
module Templates
def initialize(user_input)
@user_input = user_input
end
def to_prompt
<<~PROMPT
You are an assistant that writes code for the following context:
context: #{user_input}
PROMPT
end
end
end
end
end
end
Because we support multiple AI providers, you may also use those providers for the same example:
Gitlab::Llm::VertexAi::Client.new(user, unit_primitive: 'your_feature')
Gitlab::Llm::Anthropic::Client.new(user, unit_primitive: 'your_feature')
Monitoring
- Error ratio and response latency apdex for each Ai action can be found on Sidekiq Service dashboard under SLI Detail:
llm_completion
. - Spent tokens, usage of each Ai feature and other statistics can be found on periscope dashboard.
- AI Gateway logs.
- AI Gateway metrics.
- Feature usage dashboard via proxy.
Logs
Overview
In addition to standard logging in the GitLab Rails Monolith instance, specialized logging is available for features based on large language models (LLMs).
Implementation
Logger Class
To implement LLM-specific logging, use the Gitlab::Llm::Logger
class.
Privacy Considerations
Important: User inputs and complete prompts containing user data must not be logged unless explicitly permitted.
Feature Flag
A feature flag named expanded_ai_logging
controls the logging of sensitive data.
Use the info_or_debug
helper method for conditional logging based on the feature flag status:
- If the feature flag is enabled for the current user, it logs the information on
info
level (logs are accessible in Kibana). - If the feature flag is disabled for the current user, it logs the information on
debug
level (logs are not accessible in Kibana).
Best Practices
When implementing logging for LLM features, consider the following:
- Identify critical information for debugging purposes.
- Ensure compliance with privacy requirements by not logging sensitive user data without proper authorization.
- Use the
info_or_debug
helper method to respect theexpanded_ai_logging
feature flag. - Structure your logs to provide meaningful insights for troubleshooting and analysis.
Example Usage
# Logging non-sensitive information
Gitlab::Llm::Logger.build.info("LLM feature initialized")
# Logging potentially sensitive information
Gitlab::Llm::Logger.build.info_or_debug(user, message:"User prompt processed: #{sanitized_prompt}")
# Logging application error information
Gitlab::Llm::Logger.build.error(user, message: "System application error: #{sanitized_error_message}")
Important: Please familiarize yourself with our Data Retention Policy and remember to make sure we are not logging user input and LLM-generated output.
Security
Refer to the secure coding guidelines for Artificial Intelligence (AI) features.
