Commit e158f805 authored by Aytekin Gel's avatar Aytekin Gel
Browse files
Changes due to PSUADE GPM10 surrogate content upload
parent 76752f3e
Loading
Loading
Loading
Loading
+0 −33
Changes for Case1_ParticleSettling/DeterministicCalibration/PSUADE/1_ResponseSurface/Quadratic/PSbuildRS_2.in: 0 added lines, 33 removed lines.
Original line number Original line Diff line number Diff line
load ../../psData_OLH_n120_i6_o1_y2 # load data file
ana_expert      # psuade> analysis expert mode on
printlevel 3    # psuade> printlevel set from 0 to 3
rscheck         # Check for best data-fitted surrogate model
2               # Select Linear regression as response surface method
1               # Quantity of interest no
y               # Perform cross-cross_validation
120             # Enter the number of groups to validate : (2 - 120)
n               # Random selection of leave-out groups ? (y or n)
sys mv RSFA_CV_err.m R2_QUAD_120F_RSFA_CV_err.m # Rename the CV error file before next one
sys mv RSFA_training_err.m R2_QUAD_RSFA_training_err.m # Rename the training error file before next one
rs2
256             # Grid resolution ? (32 - 256)
2               # Available response surface tools:  select Quadratic
6               # Enter the input for x axis (1 - 7) :
5               # Enter the input for y axis (1 - 7), not 1 : 2
y               # Set other nominal values automatically ? (y or n)
1               # Enter output number (1 - 1) :
n               #  Ymin and Ymax found = 2.037723e-01 3.421112e-01. Set lower threshold ? (y or n) :
n               # Set upper threshold ? (y or n) : n
sys mv matlabrs2.m R2_QUAD_rs2_x6x5.m    # Rename the response surface constructed
rs2
2               # Available response surface tools:  select LINEAR
3               # Enter the input for y axis (1 - 7), not 1 : 2
1               # Enter output number (1 - 3) :
sys mv matlabrs2.m R2_QUAD_rs2_x6x3.m    # Rename the response surface constructed
sys ls -alrt R2_QUAD*  # Check most one created after mv
q
+0 −405
File deleted.
Preview size limit exceeded, changes collapsed.
+0 −3487
File deleted.
