Main Page
Modules
Data Types List
Files
File List
File Members
get_smass.f
!vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvC
! C
3
! Module name: GET_SMASS(SMASS) C
4
! Purpose: Determine the weight of solids in the reactor C
5
! C
6
! Author: M. Syamlal Date: 30-JAN-92 C
7
! Reviewer: P. Nicoletti, W. Rogers, S. Venkatesan Date: 31-JAN-92 C
8
! C
! Revision Number: C
! Purpose: C
11
! Author: Date: dd-mmm-yy C
12
! Reviewer: Date: dd-mmm-yy C
13
! C
14
! Literature/Document References: C
15
! C
16
! Variables referenced: IMAX2, JMAX2, KMAX2, MMAX, ROP_s, DX, DY, DZ, C
17
! X, IMIN1, JMIN1. KMIN1 C
18
! Variables modified: I, J, K, M, IJK C
19
! C
20
! Local variables: None C
21
! C
22
!^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^C
23
24
SUBROUTINE
get_smass
(SMASS)
25
!...Translated by Pacific-Sierra Research VAST-90 2.06G5 12:17:31 12/09/98
26
!...Switches: -xf
27
28
! Include param.inc file to specify parameter values
29
31
! M o d u l e s
32
33
USE
check
34
USE
compar
35
USE
fldvar
36
USE
functions
37
USE
geometry
38
USE
indices
39
USE
mpi_utility
40
USE
parallel
41
USE
param
42
USE
param1
43
USE
physprop
44
IMPLICIT NONE
45
46
! G l o b a l P a r a m e t e r s
47
48
49
! D u m m y A r g u m e n t s
50
51
52
! Total Weight of solids in the reactor
53
DOUBLE PRECISION
SMASS
54
55
! Solids phase
56
INTEGER
M
57
58
59
60
smass =
zero
61
DO
m = 1,
mmax
62
smass = smass +
accumulation
rop_s
(1, m))
63
END DO
64
65
RETURN
66
END SUBROUTINE
get_smass
67
68
!// Comments on the modifications for DMP version implementation
69
!// 001 Include header file and common declarations for parallelization
70
!// 350 Changed do loop limits: 1,ijkmax2-> ijkstart3, ijkend3
71
!// 400 Added mpi_utility module and other global reduction (global_all_sum) call
72
mpi_utility
Definition:
mpi_utility_mod.f:6
param1
Definition:
param1_mod.f:2
functions
Definition:
functions_mod.f:1
compar
Definition:
compar_mod.f:12
check
Definition:
check_mod.f:18
indices
Definition:
indices_mod.f:9
parallel
Definition:
parallel_mod.f:3
check::accumulation
double precision function accumulation(ro)
Definition:
check_mod.f:829
physprop::mmax
integer mmax
Definition:
physprop_mod.f:19
get_smass
subroutine get_smass(SMASS)
Definition:
get_smass.f:25
fldvar
Definition:
fldvar_mod.f:11
param
Definition:
param_mod.f:2
physprop
Definition:
physprop_mod.f:10
fldvar::rop_s
Definition:
fldvar_mod.f:51
geometry
Definition:
geometry_mod.f:11
param1::zero
Definition:
param1_mod.f:27
get_smass.f
Generated by
1.8.11
