Main Page
Modules
Data Types List
Files
File List
File Members
Modules
Variables
run_mod.f File Reference
Modules
module
run
subroutine
run::get_tunit
(TLEFT, TUNIT)
Variables
character(len=60)
run::run_name
character(len=60)
run::description
character(len=16)
run::units
character(len=16)
run::run_type
logical
run::automatic_restart
integer
run::iter_restart
character(len=10)
run::id_version
double precision
run::time
double precision
run::tstop
double precision
run::dt
double precision
run::odt
logical
run::steady_state
integer
run::nstep
integer
run::nsteprst
integer, dimension(dim_eqs)
run::discretize
logical
run::chi_scheme
logical, dimension(0:dim_m)
run::momentum_x_eq
run::momentum_y_eq
run::momentum_z_eq
logical
run::jackson
logical
run::ishii
logical
run::model_b
logical
run::added_mass
integer
run::m_am
logical
run::k_epsilon
logical
run::energy_eq
logical
run::def_cor
logical
run::fpfoi
logical
run::cn_on
logical
run::granular_energy
run::species_eq
logical
run::any_species_eq
logical
run::call_usr
logical
run::persistent_mode
logical
run::call_dqmom
logical
run::subgrid_wall
double precision
run::filter_size_ratio
character(64)
run::cd_function
double precision
run::lam_hys
logical
run::simonin
logical
run::ahmadi
logical
run::friction
integer
run::savage
logical
run::schaeffer
logical
run::blending_stress
logical
run::tanh_blend
logical
run::sigm_blend
logical
run::jenkins
logical
run::bc_jj_m
logical
run::phip_out_jj
integer
run::phip_out_iter
logical
run::shear
double precision
run::v_sh
logical
run::yu_standish
logical
run::fedors_landel
logical
run::chk_batchq_end
double precision
run::batch_wallclock
double precision
run::term_buffer
logical
run::auto_restart
logical
run::reinitializing
= .FALSE.
integer, dimension(2)
run::timestep_fail_rate
integer
run::dt_dir
= -1
double precision
run::dt_max
double precision
run::dt_min
double precision
run::dt_fac
double precision
run::dt_prev
logical
run::use_dt_prev
double precision
run::c_fac
logical
run::detect_stall
logical
run::debug_resid
logical, dimension(dim_m)
run::solve_ros
logical
run::any_solve_ros
character(len=3), dimension(dim_m)
run::solids_model
logical
run::tfm_solids
logical
run::dem_solids
logical
run::pic_solids
integer
run::tfm_count
= 0
integer
run::dem_count
= 0
integer
run::pic_count
= 0
integer
run::ier
character(len=4)
run::tunit
run_mod.f
Generated by
1.8.11
