51 DOUBLE PRECISION ::
dt 54 DOUBLE PRECISION ::
odt 285 DOUBLE PRECISION,
INTENT(INOUT) :: TLEFT
286 CHARACTER(LEN=4) :: TUNIT
289 IF (tleft < 3600.0d0)
THEN 292 tleft = tleft/3600.0d0
294 IF (tleft >= 24.)
THEN logical, dimension(0:dim_m) momentum_y_eq
character(len=60) description
logical, dimension(0:dim_m) momentum_x_eq
character(len=60) run_name
logical, dimension(0:dim_m) species_eq
integer, parameter dim_eqs
logical, dimension(0:dim_m) momentum_z_eq
logical, dimension(dim_m) solve_ros
logical automatic_restart
character(len=3), dimension(dim_m) solids_model
integer, dimension(2) timestep_fail_rate
double precision term_buffer
character(64) cd_function
character(len=16) run_type
double precision filter_size_ratio
double precision batch_wallclock
integer, dimension(dim_eqs) discretize
subroutine get_tunit(TLEFT, TUNIT)
character(len=10) id_version
