8.3.10. Boundary Conditions
A flow plane must have a wall cell (or an outside boundary) on one side and a flow cell on the other side. The BC section is also used to specify obstacles in the flow domain. Obstacles are 3D regions, just as for the IC regions: X_w X_e, Y_s Y_n, and Z_t Z_b. By default the outside boundary is initialized as no-slip walls. For cylindrical coordinates the axis is initialized as a free-slip wall.
8.3.10.1. BC_X_W(BC)
  • \(1 \le BC \le 500\)
8.3.10.2. BC_X_E(BC)
8.3.10.3. BC_Y_S(BC)
8.3.10.4. BC_Y_N(BC)
8.3.10.5. BC_Z_B(BC)
8.3.10.6. BC_Z_T(BC)
8.3.10.7. BC_I_W(BC)
8.3.10.8. BC_I_E(BC)
8.3.10.9. BC_J_S(BC)
8.3.10.10. BC_J_N(BC)
8.3.10.11. BC_K_B(BC)
8.3.10.12. BC_K_T(BC)
K index of the top-most cell.
8.3.10.13. BC_TYPE(BC)
Type of boundary.
Table 8.61 Valid Values
DUMMY
The specified boundary condition is ignored. This is useful for turning off some boundary conditions without having to delete them from the file.
MI / MASS_INFLOW
Mass inflow rates for gas and solids phases are specified at the boundary.
MO / MASS_OUTFLOW
The specified values of gas and solids mass outflow rates at the boundary are maintained, approximately. This condition should be used sparingly for minor outflows, when the bulk of the outflow is occurring through other constant pressure outflow boundaries.
PI / P_INFLOW
Inflow from a boundary at a specified constant pressure. To specify as the west, south, or bottom end of the computational region, add a layer of wall cells to the west, south, or bottom of the PI cells. Users need to specify all scalar quantities and velocity components. The specified values of fluid and solids velocities are only used initially as MFIX computes these values at this inlet boundary.
PO / P_OUTFLOW
Outflow to a boundary at a specified constant pressure. To specify as the west, south, or bottom end of the computational region, add a layer of wall cells to the west, south, or bottom of the PO cells.
FSW / FREE_SLIP_WALL
Velocity gradients at the wall vanish. If BC_JJ_PS is equal to 1, the Johnson-Jackson boundary condition is used for solids. A FSW is equivalent to using a PSW with \(Hw=0\).
NSW / NO_SLIP_WALL
All components of the velocity vanish at the wall. If BC_JJ_PS is equal to 1, the Johnson-Jackson boundary condition is used for solids. A NSW is equivalent to using a PSW with \(vw=0\) and \(Hw\) undefined.
PSW / PAR_SLIP_WALL
Partial slip at the wall implemented as the boundary condition: \(\frac{\mathrm{d}v}{\mathrm{d}n} + H_w (v - v_w) = 0\) where \(n\) is the normal pointing from the fluid into the wall. The coefficients \(Hw\) and \(vw\) should be specified. For free-slip set \(Hw = 0\). For no-slip leave \(Hw\) undefined (Hw=+inf) and set \(vw = 0\). To set \(Hw\) = +inf, leave it unspecified. If BC_JJ_PS is equal to 1, the Johnson-Jackson boundary condition is used for solids.
8.3.10.14. BC_PSD_TYPE(BC, PHASE)
Table 8.62 Valid Values
MONO
Uniform particle size.
NORMAL
LOG_NORMAL
CUSTOM
8.3.10.15. BC_PSD_MEAN_DP(BC, PHASE)
Mean value of particle size distribution of solids phase in the BC region. For a log-normal psd, The mean diameter (µ) and standard deviation (𝜎) will be used to compute the log-normal parameters µ_ln and 𝜎_ln : µ_ln = ln(µ²/√(µ² + 𝜎²)) and 𝜎_ln = √(ln(1 + (𝜎/µ)²)))
8.3.10.16. BC_PSD_STDEV(BC, PHASE)
Standard deviation of particle size distribution of solids phase in the BC region. For a log-normal psd, The mean diameter (µ) and standard deviation (𝜎) will be used to compute the log-normal parameters µ_ln and 𝜎_ln : µ_ln = ln(µ²/√(µ² + 𝜎²)) and 𝜎_ln = √(ln(1 + (𝜎/µ)²)))
8.3.10.17. BC_PSD_MAX_DP(BC, PHASE)
8.3.10.18. BC_PSD_MIN_DP(BC, PHASE)
8.3.10.19. BC_MI_START_TIME(BC)
Mass inlet starting time (sec.).
8.3.10.20. BC_MI_END_TIME(BC)
Mass inlet ending time (sec.).
8.3.10.21. BC_HW_G(BC)
Gas phase Hw for partial slip boundary.
8.3.10.22. BC_HW_S(BC, PHASE)
Solids phase Hw for partial slip boundary.
8.3.10.23. BC_UW_G(BC)
Gas phase Uw for partial slip boundary.
8.3.10.24. BC_UW_S(BC, PHASE)
Solids phase Uw for partial slip boundary.
8.3.10.25. BC_VW_G(BC)
Gas phase vw for partial slip boundary.
8.3.10.26. BC_VW_S(BC, PHASE)
Solids phase vw for partial slip boundary.
8.3.10.27. BC_WW_G(BC)
Gas phase Ww for partial slip boundary.
8.3.10.28. BC_WW_S(BC, PHASE)
Solids phase Ww for partial slip boundary.
8.3.10.29. BC_JJ_PS(BC)
Table 8.63 Valid Values
Do not use Johnson and Jackson partial slip bc. Default if granular energy transport equation is not solved.
Use Johnson and Jackson partial slip bc. Default if granular energy transport equation is solved.
8.3.10.30. BC_JJ_M
Use a modified version of Johnson and Jackson
partial slip BC (BC_JJ_PS BC) with a variable specularity coefficient.
8.3.10.31. BC_THETAW_M(BC, PHASE)
Specified wall value \({\Theta}w_M\) in diffusion boundary condition: \(\frac{\mathrm{d}{\Theta_M}}{\mathrm{d}n} + Hw(\Theta_M - {\Theta}w_M) = C\), where \(n\) is the fluid-to-wall normal.
8.3.10.32. BC_HW_THETA_M(BC, PHASE)
Transfer coefficient \(Hw\) in diffusion boundary condition: \(\frac{\mathrm{d}{\Theta_M}}{\mathrm{d}n} + Hw(\Theta_M - {\Theta}w_M) = C\), where \(n\) is the fluid-to-wall normal.
8.3.10.33. BC_C_THETA_M(BC, PHASE)
Specified constant flux \(C\) in diffusion boundary condition: \(\frac{\mathrm{d}{\Theta_M}}{\mathrm{d}n} + Hw(\Theta_M - {\Theta}w_M) = C\), where \(n\) is the fluid-to-wall normal.
8.3.10.34. BC_HW_T_G(BC)
Gas phase heat transfer coefficient \(Hw\) in diffusion boundary condition: \(\frac{\mathrm{d}T_g}{\mathrm{d}n} + Hw (T_g - Tw_g) = C\), where \(n\) is the fluid-to-wall normal.
8.3.10.35. BC_TW_G(BC)
Specified gas phase wall temperature \(Tw_g\) in diffusion boundary condition: \(\frac{\mathrm{d}T_g}{\mathrm{d}n} + Hw (T_g - Tw_g) = C\), where \(n\) is the fluid-to-wall normal.
8.3.10.36. BC_C_T_G(BC)
Specified constant gas phase heat flux \(C\) in diffusion boundary condition: \(\frac{\mathrm{d}T_g}{\mathrm{d}n} + Hw (T_g - Tw_g) = C\), where \(n\) is the fluid-to-wall normal.
8.3.10.37. BC_HW_T_S(BC, PHASE)
Solids phase heat transfer coefficient \(Hw\) in diffusion boundary condition: \(\frac{\mathrm{d}T_s}{\mathrm{d}n} + Hw (T_s - Tw_s) = C\), where \(n\) is the fluid-to-wall normal.
8.3.10.38. BC_TW_S(BC, PHASE)
Specified solids phase wall temperature \(Tw_s\) in diffusion boundary condition: \(\frac{\mathrm{d}T_s}{\mathrm{d}n} + Hw (T_s - Tw_s) = C\), where \(n\) is the fluid-to-wall normal.
8.3.10.39. BC_C_T_S(BC, PHASE)
Specified constant solids phase heat flux \(C\) in diffusion boundary condition: \(\frac{\mathrm{d}T_s}{\mathrm{d}n} + Hw (T_s - Tw_s) = C\), where \(n\) is the fluid-to-wall normal.
8.3.10.40. BC_HW_X_G(BC, SPECIES)
  • \(1 \le Species \le 100\)
Gas phase species mass transfer coefficient \(Hw\) in diffusion boundary condition: \(\frac{\mathrm{d}X_g}{\mathrm{d}n} + Hw (X_g - Xw_g) = C\), where \(n\) is the fluid-to-wall normal.
8.3.10.41. BC_XW_G(BC, SPECIES)
Specified wall gas species mass fraction \(Xw_g\) in diffusion boundary condition: \(\frac{\mathrm{d}X_g}{\mathrm{d}n} + Hw (X_g - Xw_g) = C\), where \(n\) is the fluid-to-wall normal.
8.3.10.42. BC_C_X_G(BC, SPECIES)
Specified constant gas species mass flux \(C\) in diffusion boundary condition: \(\frac{\mathrm{d}X_g}{\mathrm{d}n} + Hw (X_g - Xw_g) = C\), where \(n\) is the fluid-to-wall normal.
8.3.10.43. BC_HW_X_S(BC, PHASE, SPECIES)
Solid phase species mass transfer coefficient \(Hw\) in diffusion boundary condition: \(\frac{\mathrm{d}X_s}{\mathrm{d}n} + Hw (X_s - Xw_s) = C\), where \(n\) is the fluid-to-wall normal.
8.3.10.44. BC_XW_S(BC, PHASE, SPECIES)
Specified solids species mass fraction at the wall \(Xw_s\) in diffusion boundary condition: \(\frac{\mathrm{d}X_s}{\mathrm{d}n} + Hw (X_s - Xw_s) = C\), where \(n\) is the fluid-to-wall normal.
8.3.10.45. BC_C_X_S(BC, PHASE, SPECIES)
Specified constant solids species mass flux \(C\) in diffusion boundary condition: \(\frac{\mathrm{d}X_s}{\mathrm{d}n} + Hw (X_s - Xw_s) = C\), where \(n\) is the fluid-to-wall normal.
8.3.10.46. BC_HW_SCALAR(BC, SCALAR EQ.)
Scalar transfer coefficient \(Hw\) in diffusion boundary condition: \(\frac{\mathrm{d}Scalar}{\mathrm{d}n} + Hw (Scalar - ScalarW) = C\), where \(n\) is the fluid-to-wall normal.
8.3.10.47. BC_SCALARW(BC, SCALAR EQ.)
Specified scalar value at the wall \(ScalarW\) in diffusion boundary condition: \(\frac{\mathrm{d}Scalar}{\mathrm{d}n} + Hw (Scalar - ScalarW) = C\), where \(n\) is the fluid-to-wall normal.
8.3.10.48. BC_C_SCALAR(BC, SCALAR EQ.)
Specified constant scalar flux \(C\) in diffusion boundary condition: \(\frac{\mathrm{d}Scalar}{\mathrm{d}n} + Hw (Scalar - ScalarW) = C\), where \(n\) is the fluid-to-wall normal.
8.3.10.49. BC_EP_G(BC)
8.3.10.50. BC_P_G(BC)
Gas pressure at the BC plane.
8.3.10.51. BC_ROP_S(BC, PHASE)
8.3.10.52. BC_EP_S(BC, PHASE)
8.3.10.53. BC_T_G(BC)
8.3.10.54. BC_T_S(BC, PHASE)
8.3.10.55. BC_THETA_M(BC, PHASE)
8.3.10.56. BC_X_G(BC, SPECIES)
8.3.10.57. BC_X_S(BC, PHASE, SPECIES)
8.3.10.58. BC_U_G(BC)
X-component of gas velocity at the BC plane.
8.3.10.59. BC_U_S(BC, PHASE)
X-component of solids-phase velocity at the BC plane.
8.3.10.60. BC_V_G(BC)
Y-component of gas velocity at the BC plane.
8.3.10.61. BC_V_S(BC, PHASE)
Y-component of solids-phase velocity at the BC plane.
8.3.10.62. BC_W_G(BC)
Z-component of gas velocity at the BC plane.
8.3.10.63. BC_W_S(BC, PHASE)
Z-component of solids-phase velocity at the BC plane.
8.3.10.64. BC_VOLFLOW_G(BC)
8.3.10.65. BC_VOLFLOW_S(BC, PHASE)
8.3.10.66. BC_MASSFLOW_G(BC)
8.3.10.67. BC_MASSFLOW_S(BC, PHASE)
8.3.10.68. BC_DT_0(BC)
The interval at the beginning when the normal
velocity at the boundary is equal to BC_Jet_g0. When restarting run, this value and BC_Jet_g0 should be specified such that the transient jet continues correctly. MFIX does not store the jet conditions. For MASS_OUTFLOW boundary conditions, BC_DT_0 is the time period to average and print the outflow rates. The adjustment of velocities to get a specified mass or volumetric flow rate is based on the average outflow rate.
8.3.10.69. BC_JET_G0(BC)
8.3.10.70. BC_DT_H(BC)
8.3.10.71. BC_JET_GH(BC)
8.3.10.72. BC_DT_L(BC)
8.3.10.73. BC_JET_GL(BC)
8.3.10.74. BC_SCALAR(BC, SCALAR EQ.)
8.3.10.75. BC_K_TURB_G(BC)
8.3.10.76. BC_E_TURB_G(BC)
8.3.10.77. BC_PIC_MI_CONST_STATWT(BC, PHASE)
Flag to specify the constant statistical
weight for inflowing computational particles/parcels. Actual number of parcels will be automatically computed.
8.3.10.78. BC_PO_APPLY_TO_DES(BC)
Flag to make the PO BC invisible to discrete solids.
Set this flag to .FALSE. to remove this BC for discrete solids.
8.3.10.79. BC_MI_APPLY_TO_DES(BC)
