8.3.3. Numerical Parameters
This section contains keywords for defining numerical parameters. Keywords related to solving the governing equations (e.g., LEQ_IT, DISCRETIZE, UR_FAC, etc.) are dimensioned for the ten types of equations:
Index
Equation Type
Gas Pressure
Solids Volume Fraction
3
Gas and Solids U Momentum Equation
4
Gas and Solids V Momentum Equation
5
Gas and Solids W Momentum Equation
6
Gas and Solids Energy Equations (Temperature)
7
Gas and Solids Species Mass Fractions
8
Granular Temperature
User-Defined Scalar and K-Epsilon Equation
DES Diffusion Equation
For example, LEQ_IT(3) = 10, specifies to use 10 iterations within the linear equation solver for the U Momentum Equations (of type 3).
8.3.3.1. MAX_NIT
8.3.3.2. NORM_G
8.3.3.3. NORM_S
8.3.3.4. PPG_DEN
8.3.3.5. EPP_DEN
8.3.3.6. TOL_RESID
Maximum residual at convergence (Continuity + Momentum) [1.0d-3].
8.3.3.7. TOL_RESID_T
8.3.3.8. TOL_RESID_X
8.3.3.9. TOL_RESID_TH
8.3.3.10. TOL_RESID_SCALAR
8.3.3.11. TOL_RESID_K_EPSILON
8.3.3.12. TOL_DIVERGE
8.3.3.13. TOL_SUM_RESID_ABS
8.3.3.14. DETECT_STALL
Table 8.17 Valid Values
Continue iterating if residuals stall.
Reduce time step if residuals stall.
8.3.3.15. LEQ_METHOD(EQUATION ID NUMBER)
Table 8.18 Valid Values
SOR - Successive over-relaxation
BiCGSTAB - Biconjugate gradient stabilized.
3
GMRES - Generalized minimal residual method
5
CG - Conjugate gradient
8.3.3.16. LEQ_TOL(EQUATION ID NUMBER)
8.3.3.17. LEQ_IT(EQUATION ID NUMBER)
8.3.3.18. LEQ_SWEEP(EQUATION ID NUMBER)
Table 8.19 Valid Values
RSRS
(Red/Black Sweep, Send Receive) repeated twice
ISIS
(Sweep in I, Send Receive) repeated twice
JSJS
(Sweep in J, Send Receive) repeated twice
KSKS
(Sweep in K, Send Receive) repeated twice
ASAS
(All Sweep, Send Receive) repeated twice
8.3.3.19. LEQ_PC(EQUATION ID NUMBER)
Table 8.20 Valid Values
No preconditioner
LINE
Line relaxation
DIAG
Diagonal Scaling
8.3.3.20. UR_FAC(EQUATION ID NUMBER)
Under relaxation factors. Default value: - 0.8 for equation types 1,9 - 0.5 for equation types 2,3,4,5,8 - 1.0 for equation types 6,7,10
8.3.3.21. UR_F_GS
  • 0 updates F_GS every time step
  • 1 updates F_GS every iteration
8.3.3.22. UR_KTH_SML
Under relaxation factor for conductivity coefficient associated with other solids phases for IA Theory [1.0].
8.3.3.23. DISCRETIZE(EQUATION ID NUMBER)
Table 8.21 Valid Values
First-order upwinding.
First-order upwinding (using down-wind factors).
3
Smart.
Superbee (recommended method).
5
QUICKEST (does not work).
4
ULTRA-QUICK.
7
van Leer.
6
MUSCL.
8
minmod.
Central (often unstable; useful for testing).
8.3.3.24. DEF_COR
Table 8.22 Valid Values
Use down-wind factor method (default).
Use deferred correction method.
8.3.3.25. CHI_SCHEME
Table 8.23 Valid Values
Do not use the chi-scheme.
Use the chi-scheme correction.
8.3.3.26. CN_ON
Table 8.24 Valid Values
Implicit Euler based temporal discretization scheme employed (first-order accurate in time).
Two-step implicit Runge-Kutta method based temporal discretization scheme employed. This method should be second- order accurate in time excluding pressure terms and restart time step which are first-order accurate. However, as of 2015, testing shows that second-order accuracy is not observed.
8.3.3.27. MAX_INLET_VEL_FAC
8.3.3.28. DO_TRANSPOSE
8.3.3.29. ICHECK_BICGS
8.3.3.30. OPT_PARALLEL
8.3.3.31. USE_DOLOOP
8.3.3.32. IS_SERIAL
Calculate dot-products more efficiently (Serial runs only.)
8.3.3.33. DIL_EP_S
8.3.3.34. ZERO_EP_S
Minimum value of solids volume fraction tracked It is strongly encouraged to keep the default value of 1E-8.
8.3.3.35. ZERO_X_GS
Small value for species mass fraction for disregarding residual calculation It is strongly encouraged to keep the default value of 1E-7.
