8.3.6. Discrete Element
8.3.6.1. Discrete Element - Common
8.3.6.1.1. PARTICLES
8.3.6.1.2. GENER_PART_CONFIG
Table 8.43 Valid Values
Generate particle configuration based on the initial condition parameters. Data provided in the particle_input.dat file, if present, is ignored.
Particle position and velocity data are provided in the particle_input.dat file. A runtime error occurs if this file is not provided.
8.3.6.1.3. DES_ONEWAY_COUPLED
Run one-way coupled simulations [default .FALSE.].
Table 8.44 Valid Values
8.3.6.1.4. DES_INTG_METHOD
Time stepping scheme.
Table 8.45 Valid Values
EULER
First-order Euler scheme.
ADAMS_BASHFORTH
Second-order ADAMS_BASHFORTH scheme (DEM only)
8.3.6.1.5. DESGRIDSEARCH_IMAX
8.3.6.1.6. DESGRIDSEARCH_JMAX
8.3.6.1.7. DESGRIDSEARCH_KMAX
8.3.6.1.8. DES_INTERP_SCHEME
Table 8.46 Valid Values
Do not use interpolation.
GARG_2012
Interpolate to/from a particle’s position using the corners (nodes) of the fluid cells. This was the default behavior prior to the 2015-1 Release. See Garg et al. (2012) Documentation of the open-source MFiX-DEM software for gas-solids flows.
SQUARE_DPVM
Divided Particle Volume Method: Information is interpolated to/from a particles position using a square filter of size DES_INTERP_WIDTH.
LINEAR_HAT
Linear interpolation: Hat functions are used to distribute particle information.
8.3.6.1.9. DES_INTERP_WIDTH
8.3.6.1.10. DES_INTERP_ON
Table 8.47 Valid Values
8.3.6.1.11. DES_INTERP_MEAN_FIELDS
Table 8.48 Valid Values
8.3.6.1.12. DES_DIFFUSE_WIDTH
  • The DES diffusion equation is listed as equation type 10 in the Numerical Parameters section.
8.3.6.1.13. DES_EXPLICITLY_COUPLED
Table 8.49 Valid Values
8.3.6.2. Discrete Element Model
8.3.6.2.1. NFACTOR
8.3.6.2.2. NEIGHBOR_SEARCH_N
8.3.6.2.4. NEIGHBOR_SEARCH_RAD_RATIO
8.3.6.2.5. FACTOR_RLM
8.3.6.2.6. USE_VDH_DEM_MODEL
8.3.6.2.7. DES_COLL_MODEL
Table 8.51 Valid Values
LSD
HERTZIAN
The Hertzian model. Requires: DES_ET_INPUT, DES_ET_WALL_INPUT, E_YOUNG, EW_YOUNG V_POISSON, VW_POISSON.
8.3.6.2.8. KN
8.3.6.2.9. KT_FAC
8.3.6.2.10. KN_W
8.3.6.2.11. KT_W_FAC
8.3.6.2.12. MEW
8.3.6.2.13. MEW_W
8.3.6.2.14. DES_EN_INPUT(INDEX)
8.3.6.2.15. DES_EN_WALL_INPUT(INDEX)
  • \(1 \le Index \le MMAX\)
8.3.6.2.16. DES_ET_INPUT(INDEX)
8.3.6.2.17. DES_ET_WALL_INPUT(INDEX)
8.3.6.2.18. DES_ETAT_FAC
Table 8.52 Valid Values
UNDEFINED
8.3.6.2.19. DES_ETAT_W_FAC
Table 8.53 Valid Values
UNDEFINED
8.3.6.2.20. EW_YOUNG
8.3.6.2.21. VW_POISSON
8.3.6.2.22. E_YOUNG(PHASE)
8.3.6.2.23. V_POISSON(PHASE)
8.3.6.2.24. USE_COHESION
8.3.6.2.25. VAN_DER_WAALS
8.3.6.2.26. HAMAKER_CONSTANT
8.3.6.2.27. WALL_HAMAKER_CONSTANT
8.3.6.2.28. VDW_OUTER_CUTOFF
8.3.6.2.29. VDW_INNER_CUTOFF
8.3.6.2.30. WALL_VDW_OUTER_CUTOFF
8.3.6.2.31. WALL_VDW_INNER_CUTOFF
8.3.6.2.32. ASPERITIES
8.3.6.2.33. DES_CONV_CORR
Table 8.54 Valid Values
RANZ_1952
GUNN
WAKAO
TAVASSOLI
8.3.6.2.34. DES_MIN_COND_DIST
8.3.6.2.35. FLPC
8.3.6.2.36. DES_EM(PHASE)
Emissivity of solids phase.
8.3.6.2.37. E_YOUNG_ACTUAL(PHASE)
8.3.6.2.38. EW_YOUNG_ACTUAL
8.3.6.2.39. V_POISSON_ACTUAL(PHASE)
8.3.6.2.40. VW_POISSON_ACTUAL
8.3.6.2.41. MINIMIZE_DES_FACET_LIST
8.3.6.2.42. REMOVE_ROGUE_PARTICLES
Flag to remove rogue particles. A rogue particle is defined as a particle that goes out of the MFiX box outside of a defined pressure or mass outlet BC.
8.3.6.2.43. DTSOLID_FACTOR
8.3.6.2.44. DTSOLID_UPDATE_DT
8.3.6.2.45. DES_BUFF_RESIZE_FACTOR
8.3.6.2.46. DLB_DT
Table 8.55 Valid Values
UNDEFINED
>0
8.3.6.2.47. DLB_EGW
Table 8.56 Valid Values
>=0
8.3.6.3. Particles in Cell
8.3.6.3.1. FRIC_EXP_PIC
8.3.6.3.2. PSFAC_FRIC_PIC
8.3.6.3.3. MPPIC_COEFF_EN1
8.3.6.3.4. FRIC_NON_SING_FAC
8.3.6.3.5. MPPIC_COEFF_EN_WALL
8.3.6.3.6. MPPIC_COEFF_ET_WALL
8.3.6.3.7. MPPIC_VELFAC_COEFF
8.3.6.3.8. PIC_CFL
8.3.6.3.9. PIC_CFL_PARCEL_FRACTION
8.3.6.3.10. PIC_CFL_CONTROL
8.3.6.3.11. PIC_COLLISION_DAMPING
