8.3.1. Run Control
8.3.1.1. RUN_NAME
required
8.3.1.2. DESCRIPTION
8.3.1.3. PROJECT_VERSION
8.3.1.4. UNITS
required
Table 8.2 Valid Values
cgs
All input and output in CGS units (g, cm, s, cal).
SI
8.3.1.5. RUN_TYPE
required
Type of run.
Table 8.3 Valid Values
new
RESTART_1
RESTART_2
8.3.1.6. TIME
8.3.1.7. TSTOP
Simulation stop time.
8.3.1.8. OPTFLAG1
Use nrel-cu optimization routines?.
8.3.1.9. DT
8.3.1.10. DT_MAX
Maximum time step size.
8.3.1.11. DT_MIN
Minimum time step size.
8.3.1.12. DT_FAC
8.3.1.13. PERSISTENT_MODE
Table 8.4 Valid Values
Abort run when DT < DT_MIN.
8.3.1.14. AUTO_RESTART
8.3.1.15. MOMENTUM_X_EQ(PHASE)
  • \(0 \le Phase \le 10\)
Table 8.5 Valid Values
Solve X-momentum equations.
8.3.1.16. MOMENTUM_Y_EQ(PHASE)
Table 8.6 Valid Values
Solve Y-momentum equations.
8.3.1.17. MOMENTUM_Z_EQ(PHASE)
Table 8.7 Valid Values
Solve Z-momentum equations.
8.3.1.18. JACKSON
Table 8.8 Valid Values
Default form.
8.3.1.19. ISHII
Table 8.9 Valid Values
Default form.
8.3.1.20. ENERGY_EQ
Solve energy equations.
Table 8.10 Valid Values
8.3.1.21. SPECIES_EQ(PHASE)
Table 8.11 Valid Values
Solve species equations.
8.3.1.22. TURBULENCE_MODEL
Table 8.12 Valid Values
No turbulence model.
MIXING_LENGTH
K_EPSILON
8.3.1.23. MU_GMAX
8.3.1.24. DRAG_TYPE
Table 8.13 Valid Values
SYAM_OBRIEN
GIDASPOW
GIDASPOW_BLEND
WEN_YU
KOCH_HILL
BVK
TPKKV
HYS
GAO
SARKAR
RADL
TGS
DIFELICE
DIFELICE_GANSER
USER_DRAG
GIDASPOW_PCF
(TFM only). see GIDASPOW
GIDASPOW_BLEND_PCF
WEN_YU_PCF
(TFM only). see WEN_YU
KOCH_HILL_PCF
(TFM only). see KOCH_HILL
8.3.1.25. DRAG_C1
8.3.1.26. DRAG_D1
8.3.1.27. LAM_HYS
8.3.1.28. SPHERICITY_DG
8.3.1.29. REF_LENGTH_DG
8.3.1.30. SUBGRID_TYPE
Subgrid models.
Table 8.14 Valid Values
Igci
Milioli
8.3.1.31. FILTER_SIZE_RATIO
8.3.1.32. SUBGRID_WALL
Table 8.15 Valid Values
8.3.1.33. MODEL_B
Table 8.16 Valid Values
Use Model A. See J.X. Bouillard and R.W. Lyczkowski (1991), Powder Tech, 68:31-51.
8.3.1.34. NSCALAR
to solve.
8.3.1.35. PHASE4SCALAR(SCALAR EQUATION)
8.3.1.36. PPO
Flag to run the pre-processing (mesh generation) only and exit.
