8.3.8. Solids Phase
8.3.8.1. SOLIDS_MODEL(PHASE)
Table 8.57 Valid Values
TFM
Two-fluid model (continuum)
DEM
Discrete element model
CGP
Coarse-grained particle
PIC
Multiphase particle-in-cell
8.3.8.2. MMAX
Applies to Solids Model(s): TFM, DEM
Number of solids phases.
8.3.8.3. D_P0(PHASE)
8.3.8.4. RO_S0(PHASE)
8.3.8.5. X_S0(PHASE, SPECIES)
8.3.8.6. RO_XS0(PHASE, SPECIES)
8.3.8.7. INERT_SPECIES(PHASE)
8.3.8.8. DIL_INERT_X_VSD(PHASE)
8.3.8.9. DIL_FACTOR_VSD
8.3.8.10. K_S0(PHASE)
8.3.8.11. KS_MODEL(PHASE)
Table 8.58 Valid Values
CONST_EFF
USR
Bauer
Musser
8.3.8.12. C_PS0(PHASE)
8.3.8.13. MW_S(PHASE, SPECIES)
8.3.8.14. NMAX_S(PHASE)
8.3.8.15. SPECIES_S(PHASE, SPECIES)
8.3.8.16. SPECIES_ALIAS_S(PHASE, SPECIES)
8.3.8.17. CGP_STAT_WT(PHASE)
8.3.8.18. CGP_D_P0(PHASE)
