8.5. How to setup PIC simulations¶
This document explains how to setup PIC simulations (statistical weight, PIC parameters, mesh).
8.5.1. How To Choose a Good Statistical Weight for PIC Runs?¶
8.5.2. Extra info and Examples:¶
8.5.3. Meshing Basics for PIC Runs¶
There are three common mistakes a user may make when setting up a PIC run. The first represents an entire misunderstanding of MFIX-PIC which is necessarily a 3-D model. That means, you cannot specify a 2-D simulation with MFIX-PIC. Second, the interpolation algorithm which undergirds the MFIX-PIC model requires a minimum of 3-cells in each direction through a geometry to give a robust solution. It is important to check small geometric regions of the mesh that might pass through an orifice or channel to assure that there are at least 3 cells available for calculations to work in a hydrodynamically stable way. Smaller cell distributions will not crash the model, but you may get unexpected flow behavior. Finally, choosing statistical weights that in comparison to mesh give less than one parcel per mesh cell will give errant solutions. (See section on choosing good statistical weights.) Note that one of the benefits of PIC is that it allows for a somewhat coarse mesh with a large particle count, but a user needs to balance mesh and parcel count in a reasonable way.
8.5.4. Choosing Primary PIC Parameters¶
8.5.5. Choosing Secondary PIC parameters¶
8.5.6. Collision Damping¶
8.5.7. Frequently Asked Questions¶
FAQ: Why can’t I define parcels per cell instead of particles per parcel?
FAQ: What is a good number (or range) for the number of parcels per cells
FAQ: What solids model parameter values work best for the PIC model when running 2 densities that are roughly 10x different in magnitude?
