3.19. Three-dimensional DEM hopper¶
5 cm diameter hopper |
10 x 25 x 10 |
0.003 m |
NA |
NA |
3.19.1. Create a new project¶
3.19.2. Select model parameters¶
Solverdrop-down menuCheck the
Disable Fluid Solver (Pure Granular Flow)checkbox.
3.19.3. Enter the geometry¶
wizard menu and select the
hopperwizardSelect
applyto build the hopper stl filePress the
Autosizebutton to fit the domain extents to the geometryPress the
3.19.4. Enter the mesh¶
10for the x cell valueEnter
25for the y cell valueEnter
10for the z cell value
3.19.5. Create regions for initial and boundary condition specification¶
namesuch as “walls”Check the
Select Facets (STL)checkbox to turn the region into a STL region. The facets of the hopper should now be selected.
the Y direction by:
Slice facets.Check the
Filter facets based on normalscheckboxEnter a vector pointed in the positive
Namefield (“outlet”)
Namefield (“solids”)Enter
ymin/3in theFrom YfieldEnter
0in theTo Yfield
3.19.6. Create a solid¶
On the Solids pane
button to create a new solid
In the DEM sub-pane, check Enable automatic particle generation checkbox
3.19.7. Create Initial Conditions¶
button to create a new initial condition
Select regiondialog, select the “solids” region and clickOKOn the
solidssub-pane, enter0.4in theVolume fractionfield
3.19.8. Create Boundary Conditions¶
the hopper by:
clicking the
Select regiondialog, select “No Slip Wall” from theBoundary typedrop-down menuSelect the “walls” region and click
clicking the
3.19.9. Select output options¶
OutputpaneOn the
On the “select region” dialog, select “particle data” from the
output typedrop-down menuSelect the “Background IC” region from the list to save particle data over the entire domain
DiameterandTranslational velocitycheckboxes
3.19.10. Change run parameters¶
Change
Stop timeto2.0secondsChange
Time stepto1e-3secondsChange
3.19.11. Run the project¶
Save project by clicking
Rundialog, select the default solverClick the
3.19.12. View results¶
