Two-dimensional fluidized bed, Two Fluid Model (TFM) —–====——————————————-
This tutorial shows how to create a two dimensional fluidized bed simulation using the two fluid model. The model setup is:
Geometry |
10 cm x 30 cm |
Mesh |
20 x 60 |
Solid diameter |
Solid density |
Gas velocity |
0.25 m/s |
Temperature |
Pressure |
3.2. Create a new project¶
On the main menu select
3.3. Select model parameters¶
On the Model
drop-down menu.
3.4. Enter the geometry¶
2 Dimensional
checkboxEnter
10/100
30/100
meters for the maximum y value
3.5. Enter the mesh¶
pane, Background
20
60
for the y cell value
3.6. Create regions for initial and boundary condition specification¶
Select the Regions
visualize the results.
Color
buttonEnter
xmin
ormin
in theFrom X
fieldEnter
xmax
ormax
in theTo X
fieldEnter
ymin
ormin
in theFrom Y
fieldEnter
ymax/2
ormax/2
in theTo Y
fieldEnter
zmin
ormin
in theFrom Z
fieldEnter
zmax
ormax
in theTo Z
From
andTo
fields already filled out for a region at the bottom of the domain, to be used by the gas inlet boundary condition.From Y
andTo Y
should equalymin
, defining an XZ-plane.Enter a name for the region in the
field (“inlet”)
From
andTo
fields already filled out for a region at the top of the domain, to be used by the pressure outlet boundary condition.From Y
andTo Y
should equalymax
field (“outlet”)
3.7. Create a solid¶
button to create a new solid
field (“glass beads”)Keep the model as “Two-Fluid Model (MFiX-TFM)”)
200e-6
2500
kg/m2 in theDensity
3.8. Create Initial Conditions¶
101325
Pa in thePressure (optional)
button.
0.4
in theVolume Fraction
3.9. Create Boundary Conditions¶
Select region
Y-axial velocity
field of “0.25” m/s
Select region
3.10. Change numeric parameters¶
On the Numerics
pane, Residuals
in theFluid Normalization
field.
3.11. Select output options¶
checkbox
to create the output
*.vtu
files in theFilename base
fieldChange the
to0.1
secondsSelect the
Volume fraction
,Pressure
, andVelocity vector
checkboxes on theFluid
sub-sub-pane
3.12. Change run parameters¶
to1e-3
secondsChange the
to1e-2
seconds
3.13. Run the project¶
Save project by clicking the
Run Solver
Run
3.14. View results¶
3D view
Change frames with the
, and
buttons
section on the sidebar.
3.15. Increase grid resolution¶
Mesh
pane, change theX Cells
to 80 and theY Cells
to 180On the
Output
pane,VTK
sub-pane, change the write interval to0.01
Save and run the project.
