11.1.6. Discrete Element
11.1.6.1. Discrete Element - Common
11.1.6.1.1. PARTICLES
11.1.6.1.2. GENER_PART_CONFIG
Table 11.33 Valid Values
Generate particle configuration based on the initial condition parameters. Data provided in the particle_input.dat file, if present, is ignored.
Particle position and velocity data are provided in the particle_input.dat file. A runtime error occurs if this file is not provided.
11.1.6.1.3. DES_ONEWAY_COUPLED
Run one-way coupled simulations [default .FALSE.].
Table 11.34 Valid Values
11.1.6.1.4. DES_INTG_METHOD
Time stepping scheme.
Table 11.35 Valid Values
EULER
First-order Euler scheme.
ADAMS_BASHFORTH
Second-order ADAMS_BASHFORTH scheme (DEM only)
11.1.6.1.5. DESGRIDSEARCH_IMAX
11.1.6.1.6. DESGRIDSEARCH_JMAX
11.1.6.1.7. DESGRIDSEARCH_KMAX
11.1.6.1.8. DES_INTERP_SCHEME
Table 11.36 Valid Values
Do not use interpolation.
GARG_2012
SQUARE_DPVM
Divided particle volume method: Information is interpolated to/from a particle’s position using a square filter of size DES_INTERP_WIDTH.
LINEAR_HAT
Linear interpolation: Hat functions are used to distribute particle information. PIC only.
DPVM_SATELLITE
Divided particle volume method using satellites.
11.1.6.1.9. DES_INTERP_WIDTH
11.1.6.1.10. DES_INTERP_ON
Table 11.37 Valid Values
11.1.6.1.11. DES_INTERP_MEAN_FIELDS
Table 11.38 Valid Values
11.1.6.1.12. DES_DIFFUSE_WIDTH
11.1.6.1.13. DES_EXPLICITLY_COUPLED
Table 11.39 Valid Values
11.1.6.1.14. DES_EPG_CLIP
Limit at which void fraction calculation is clipped for all Lagrangian modesl (DEM, PIC, CGP, SQP). IF the computed void fraction is a cell goes below DES_EPG_CLIP, it will be set to DES_EPG_CLIP. Leave DES_EPG_CLIP undefined to turn off the clipping.
11.1.6.2. Discrete Element Model
11.1.6.2.1. NFACTOR
11.1.6.2.2. NEIGHBOR_SEARCH_N
11.1.6.2.4. NEIGHBOR_SEARCH_RAD_RATIO
11.1.6.2.5. FACTOR_RLM
11.1.6.2.6. USE_VDH_DEM_MODEL
11.1.6.2.7. DES_COLL_MODEL
Table 11.41 Valid Values
LSD
HERTZIAN
The Hertzian model. Requires: DES_ET_INPUT, DES_ET_WALL_INPUT, E_YOUNG, EW_YOUNG V_POISSON, VW_POISSON.
11.1.6.2.8. KN
11.1.6.2.9. KT_FAC
11.1.6.2.10. KN_W
11.1.6.2.11. KT_W_FAC
11.1.6.2.12. MEW
11.1.6.2.13. MEW_W
11.1.6.2.14. MEW_R
11.1.6.2.15. MEW_RW
11.1.6.2.16. DES_EN_INPUT(INDEX)
11.1.6.2.17. DES_EN_WALL_INPUT(INDEX)
  • \(1 \le Index \le MMAX\)
11.1.6.2.18. DES_ET_INPUT(INDEX)
11.1.6.2.19. DES_ET_WALL_INPUT(INDEX)
11.1.6.2.20. DES_ETAT_FAC
Table 11.42 Valid Values
UNDEFINED
11.1.6.2.21. DES_ETAT_W_FAC
Table 11.43 Valid Values
UNDEFINED
11.1.6.2.22. EW_YOUNG
11.1.6.2.23. VW_POISSON
11.1.6.2.24. E_YOUNG(PHASE)
11.1.6.2.25. V_POISSON(PHASE)
11.1.6.2.26. USE_COHESION
11.1.6.2.27. VAN_DER_WAALS
11.1.6.2.28. HAMAKER_CONSTANT
11.1.6.2.29. WALL_HAMAKER_CONSTANT
11.1.6.2.30. VDW_OUTER_CUTOFF
11.1.6.2.31. VDW_INNER_CUTOFF
11.1.6.2.32. WALL_VDW_OUTER_CUTOFF
11.1.6.2.33. WALL_VDW_INNER_CUTOFF
11.1.6.2.34. ASPERITIES
11.1.6.2.35. DES_CONV_CORR
Table 11.44 Valid Values
RANZ_1952
GUNN
WAKAO
TAVASSOLI
11.1.6.2.36. DES_MIN_COND_DIST
11.1.6.2.37. FLPC
11.1.6.2.38. DES_EM(PHASE)
Emissivity of solids phase.
11.1.6.2.39. E_YOUNG_ACTUAL(PHASE)
11.1.6.2.40. EW_YOUNG_ACTUAL
11.1.6.2.41. V_POISSON_ACTUAL(PHASE)
11.1.6.2.42. VW_POISSON_ACTUAL
11.1.6.2.43. MINIMIZE_DES_FACET_LIST
11.1.6.2.44. REMOVE_ROGUE_PARTICLES
Flag to remove rogue particles. A rogue particle is defined as a particle that goes out of the MFiX box outside of a defined pressure or mass outlet BC.
11.1.6.2.45. DTSOLID_FACTOR
11.1.6.2.46. DTSOLID_UPDATE_DT
11.1.6.2.47. DES_BUFF_RESIZE_FACTOR
11.1.6.2.48. DLB_DT
Table 11.45 Valid Values
UNDEFINED
>0
11.1.6.2.49. DLB_EGW
Table 11.46 Valid Values
>=0
11.1.6.3. Particles in Cell
11.1.6.3.1. FRIC_EXP_PIC
11.1.6.3.2. PSFAC_FRIC_PIC
11.1.6.3.3. MPPIC_COEFF_EN1
11.1.6.3.4. FRIC_NON_SING_FAC
11.1.6.3.5. MPPIC_COEFF_EN_WALL
11.1.6.3.6. MPPIC_COEFF_ET_WALL
11.1.6.3.7. MPPIC_VELFAC_COEFF
11.1.6.3.8. PIC_CFL
11.1.6.3.9. PIC_CFL_PARCEL_FRACTION
11.1.6.3.10. PIC_CFL_CONTROL
11.1.6.3.11. PIC_COLLISION_DAMPING
11.1.6.3.12. PIC_CD_E
11.1.6.3.13. SQP_CONTACT_EVOLUTION
Flag to turn on/off superquadric evolution contact method.
