11.1.1. Run control
11.1.1.1. RUN_NAME
required
11.1.1.2. DESCRIPTION
11.1.1.3. PROJECT_VERSION
11.1.1.4. UNITS
required
Table 11.1 Valid Values
SI
cgs
11.1.1.5. RUN_TYPE
required
Type of run.
Table 11.2 Valid Values
new
RESTART_1
RESTART_2
11.1.1.6. PPO
Flag to run the pre-processing (mesh generation) only and exit.
11.1.1.7. TIME
11.1.1.8. TSTOP
Simulation stop time.
11.1.1.9. OPTFLAG1
Use nrel-cu optimization routines?.
11.1.1.10. DT
11.1.1.11. DT_MAX
Maximum time step size.
11.1.1.12. DT_MIN
Minimum time step size.
11.1.1.13. DT_FAC
11.1.1.14. PERSISTENT_MODE
Table 11.3 Valid Values
Abort run when DT < DT_MIN.
11.1.1.15. AUTO_RESTART
11.1.1.16. MOMENTUM_X_EQ(PHASE)
  • \(0 \le Phase \le 10\)
Table 11.4 Valid Values
Solve X-momentum equations.
11.1.1.17. MOMENTUM_Y_EQ(PHASE)
Table 11.5 Valid Values
Solve Y-momentum equations.
11.1.1.18. MOMENTUM_Z_EQ(PHASE)
Table 11.6 Valid Values
Solve Z-momentum equations.
11.1.1.19. JACKSON
Table 11.7 Valid Values
Default form.
11.1.1.20. ISHII
Table 11.8 Valid Values
Default form.
11.1.1.21. ENERGY_EQ
Solve energy equations.
Table 11.9 Valid Values
11.1.1.22. SPECIES_EQ(PHASE)
Table 11.10 Valid Values
Solve species equations.
11.1.1.23. TURBULENCE_MODEL
Table 11.11 Valid Values
No turbulence model.
MIXING_LENGTH
K_EPSILON
11.1.1.24. MU_GMAX
11.1.1.25. DRAG_TYPE
Table 11.12 Valid Values
SYAM_OBRIEN
GIDASPOW
GIDASPOW_BLEND
WEN_YU
KOCH_HILL
BVK
TPKKV
HYS
GAO
SARKAR
RADL
TGS
DIFELICE
DIFELICE_GANSER
SQP_DIFELICE_GANSER
Xi Gao, Jia Yu, Liqiang Lu, Cheng Li and William A Rogers, Development and validation of SuperDEM-CFD coupled model for simulating non-spherical particles hydrodynamics in fluidized beds, Chemical Engineering Journal, 2021,420: 127654. and G.H. Ganser, A rational approach to drag prediction of spherical and nonspherical particles, Powder Technol. 77 (1993) 143-152. This model requires specification of a sphericity and a reference length (typically the bed diameter)
SQP_DIFELICE_HOLZER_SOMMERFELD
Xi Gao, Jia Yu, Liqiang Lu, Cheng Li and William A Rogers, Development and validation of SuperDEM-CFD coupled model for simulating non-spherical particles hydrodynamics in fluidized beds, Chemical Engineering Journal, 2021,420: 127654. and A. Hölzer, M. Sommerfeld, New simple correlation formula for the drag coefficient of nonspherical particles, Powder Technology 184 (2008) 361-365.
USER_DRAG
GIDASPOW_PCF
(TFM only). see GIDASPOW
GIDASPOW_BLEND_PCF
WEN_YU_PCF
(TFM only). see WEN_YU
KOCH_HILL_PCF
(TFM only). see KOCH_HILL
11.1.1.26. DRAG_C1
11.1.1.27. DRAG_D1
11.1.1.28. LAM_HYS
11.1.1.29. SPHERICITY_DG
11.1.1.30. REF_LENGTH_DG
11.1.1.31. SUBGRID_TYPE
Subgrid models.
Table 11.13 Valid Values
Igci
Milioli
11.1.1.32. FILTER_SIZE_RATIO
11.1.1.33. SUBGRID_WALL
Table 11.14 Valid Values
11.1.1.34. MODEL_B
Table 11.15 Valid Values
Use Model A. See J.X. Bouillard and R.W. Lyczkowski (1991), Powder Tech, 68:31-51.
11.1.1.35. NSCALAR
to solve.
11.1.1.36. PHASE4SCALAR(SCALAR EQUATION)
