11.1.13. Output Control
11.1.13.1. RES_DT
required
11.1.13.2. RES_BACKUP_DT
11.1.13.3. RES_BACKUPS
11.1.13.4. SPX_DT(SP VALUE)
  • \(1 \le SP Value \le 11\)
  • SP1: void fraction (EP_G)
11.1.13.5. NRR
11.1.13.6. OUT_DT
11.1.13.7. REPORT_SOLID_INVENTORY
required
11.1.13.8. REPORT_SOLID_INVENTORY_DT
required
11.1.13.9. BREAKDOWN_SOLID_INVENTORY_BY_PHASE
required
11.1.13.10. NLOG
11.1.13.11. FULL_LOG
messages about convergence on the screen and in the .LOG file. XXX FIXME issues/1504
11.1.13.12. VERBOSE
Display the residuals and other information on the screen
11.1.13.13. RESID_STRING(RESIDUAL INDEX)
Table 11.55 Valid Values
P0
Gas pressure
PM
Solids phase M pressure
R0
Gas density
RM
Solids phase M density
U0
Gas phase U-velocity
V0
Gas phase V-velocity
W0
Gas phase W-velocity
UM
Solids phase M U-velocity
VM
Solids phase M V-velocity
WM
Solids phase M W-velocity
T0
Gas temperature
TM
Solids phase M temperature
GM
X0NN
XMNN
K0
K-Epsilon model residuals
11.1.13.14. GROUP_RESID
11.1.13.15. REPORT_NEG_DENSITY
Table 11.56 Valid Values
Log negative density errors.
11.1.13.16. REPORT_NEG_SPECIFICHEAT
Table 11.57 Valid Values
11.1.13.17. REPORT_MASS_BALANCE_DT
11.1.13.18. PHIP_OUT_JJ
11.1.13.19. BDIST_IO
11.1.13.20. BSTART_WITH_ONE_RES
11.1.13.21. MONITOR_X_W(MONITOR)
11.1.13.22. MONITOR_X_E(MONITOR)
11.1.13.23. MONITOR_Y_S(MONITOR)
11.1.13.24. MONITOR_Y_N(MONITOR)
11.1.13.25. MONITOR_Z_B(MONITOR)
11.1.13.26. MONITOR_Z_T(MONITOR)
11.1.13.27. MONITOR_NAME(MONITOR)
11.1.13.28. MONITOR_DT(MONITOR)
11.1.13.29. MONITOR_TAVG_DT(MONITOR)
11.1.13.30. MONITOR_TAVG_START(MONITOR)
11.1.13.31. MONITOR_TAVG_RESET_DT(MONITOR)
11.1.13.32. MONITOR_TAVG_SS_TOL(MONITOR)
11.1.13.33. MONITOR_TAVG_SS_SPAN(MONITOR)
11.1.13.34. MONITOR_TYPE(MONITOR)
Data monitor type.
Table 11.58 Valid Values
Point value
Sum over region
Minimum over region
3
Maximum over region
4
5
6
7
Flow rate across surface
8
Mass flow rate across surface
11
Volume integral
12
Volume-weighted average
13
Mass-weighted volume integral
14
Mass-weighted volume average
101
Sum over region
102
Minimum over region
103
Maximum over region
104
105
106
107
108
109
110
11.1.13.35. MONITOR_EP_G(MONITOR)
11.1.13.36. MONITOR_RO_G(MONITOR)
11.1.13.37. MONITOR_P_G(MONITOR)
11.1.13.38. MONITOR_U_G(MONITOR)
11.1.13.39. MONITOR_V_G(MONITOR)
11.1.13.40. MONITOR_W_G(MONITOR)
11.1.13.41. MONITOR_T_G(MONITOR)
11.1.13.42. MONITOR_MW_MIX_G(MONITOR)
11.1.13.43. MONITOR_X_G(MONITOR, SPECIES)
  • \(1 \le Species \le 100\)
11.1.13.44. MONITOR_Y_G(MONITOR, SPECIES)
11.1.13.45. MONITOR_K_TURB_G(MONITOR)
11.1.13.46. MONITOR_E_TURB_G(MONITOR)
11.1.13.47. MONITOR_EP_S(MONITOR, PHASE)
11.1.13.48. MONITOR_U_S(MONITOR, PHASE)
11.1.13.49. MONITOR_V_S(MONITOR, PHASE)
11.1.13.50. MONITOR_W_S(MONITOR, PHASE)
11.1.13.51. MONITOR_ROP_S(MONITOR, PHASE)
11.1.13.52. MONITOR_RO_S(MONITOR, PHASE)
11.1.13.53. MONITOR_P_STAR(MONITOR)
11.1.13.54. MONITOR_P_S(MONITOR, PHASE)
11.1.13.55. MONITOR_T_S(MONITOR, PHASE)
11.1.13.56. MONITOR_X_S(MONITOR, PHASE, SPECIES)
11.1.13.57. MONITOR_THETA_M(MONITOR, PHASE)
11.1.13.58. MONITOR_SCALAR(MONITOR, SCALAR EQ.)
Write scalar in region.
11.1.13.59. MONITOR_RRATE(MONITOR, RATE)
  • \(1 \le RATE \le NRRMAX\)
11.1.13.60. MONITOR_FLUID_RRATE(MONITOR, RATE)
Write fluid reaction rates in region. This keyword replaces
11.1.13.61. MONITOR_DES_RRATE(MONITOR, RATE)
Write particle/parcel reaction rates in region. Particle/parcel data
is converted to cell data.
11.1.13.62. MONITOR_PART_PHASE(MONITOR, PHASE)
11.1.13.63. MONITOR_RADIUS(MONITOR)
11.1.13.64. MONITOR_PMASS(MONITOR)
11.1.13.65. MONITOR_PCOUNT(MONITOR)
11.1.13.66. MONITOR_PVOL(MONITOR)
11.1.13.67. MONITOR_RO_P(MONITOR)
11.1.13.68. MONITOR_VEL_X(MONITOR)
11.1.13.69. MONITOR_VEL_Y(MONITOR)
11.1.13.70. MONITOR_VEL_Z(MONITOR)
11.1.13.71. MONITOR_ROT_X(MONITOR)
11.1.13.72. MONITOR_ROT_Y(MONITOR)
11.1.13.73. MONITOR_ROT_Z(MONITOR)
11.1.13.74. MONITOR_T_P(MONITOR)
11.1.13.75. MONITOR_X_P(MONITOR, SPECIES)
11.1.13.76. MONITOR_DES_USR_VAR(MONITOR, USR_VAR)
  • \(1 \le USR_VAR \le 100\)
Write des_usr_var in region.
11.1.13.77. MONITOR_PART_RRATE(MONITOR, RATE)
  • \(1 \le rate \le 100\)
11.1.13.78. MONITOR_PART_RESIDENCE_TIME(MONITOR)
11.1.13.79. WRITE_VTK_FILES
Table 11.59 Valid Values
11.1.13.80. TIME_DEPENDENT_FILENAME
Table 11.60 Valid Values
11.1.13.81. VTK_DT(VTK)
  • \(1 \le VTK \le 100\)
11.1.13.82. VTK_T_START(VTK)
11.1.13.83. VTK_T_END(VTK)
11.1.13.84. VTK_DBG_FILE(VTK)
When VTK_DBG_FILE is .TRUE., the VTK region file is only written
11.1.13.85. VTK_VAR(IDX)
  • \(1 \le IDX \le 20\)
Table 11.61 Valid Values
Void fraction (EP_g)
3
Gas velocity (U_g, V_g, W_g)
4
5
Solids density (ROP_s)
6
7
8
Scalar
Reaction rates
11
K and Epsilon
12
100
Grid Partition
101
Boundary Condition ID
102
Distance to wall
103
DEM facet count
104
DEM Neighboring facets
999
Cell IJK index
1000
Cut face normal vector
11.1.13.86. VTK_X_W(VTK)
11.1.13.87. VTK_X_E(VTK)
11.1.13.88. VTK_Y_S(VTK)
11.1.13.89. VTK_Y_N(VTK)
11.1.13.90. VTK_Z_B(VTK)
11.1.13.91. VTK_Z_T(VTK)
11.1.13.92. VTK_FILEBASE(VTK)
11.1.13.93. VTK_DATA(VTK)
Table 11.62 Valid Values
C
Cell data (VTU file).
P
Particle data (VTP file).
G
Geometry data (STL file).
F
Force chain data (VTP file).
11.1.13.94. VTK_GEO(VTK, GEO)
11.1.13.95. VTK_SELECT_MODE(VTK)
Table 11.63 Valid Values
C
P
I
11.1.13.96. VTK_NXS(VTK)
11.1.13.97. VTK_NYS(VTK)
11.1.13.98. VTK_NZS(VTK)
11.1.13.99. VTK_SLICE_TOL(VTK)
11.1.13.100. VTK_EP_G(VTK)
11.1.13.101. VTK_P_G(VTK)
11.1.13.102. VTK_VEL_G(VTK)
11.1.13.103. VTK_U_G(VTK)
11.1.13.104. VTK_V_G(VTK)
11.1.13.105. VTK_W_G(VTK)
11.1.13.106. VTK_P_STAR(VTK)
11.1.13.107. VTK_P_S(VTK, PHASE)
11.1.13.108. VTK_VEL_S(VTK, PHASE)
11.1.13.109. VTK_U_S(VTK, PHASE)
11.1.13.110. VTK_V_S(VTK, PHASE)
11.1.13.111. VTK_W_S(VTK, PHASE)
11.1.13.112. VTK_ROP_S(VTK, PHASE)
11.1.13.113. VTK_RO_S(VTK, PHASE)
11.1.13.114. VTK_EP_S(VTK, PHASE)
11.1.13.115. VTK_T_G(VTK)
11.1.13.116. VTK_T_S(VTK, PHASE)
11.1.13.117. VTK_MW_MIX_G(VTK)
11.1.13.118. VTK_X_G(VTK, GAS SPECIES)
11.1.13.119. VTK_Y_G(VTK, GAS SPECIES)
11.1.13.120. VTK_X_S(VTK, PHASE, SOLIDS SPECIES)
11.1.13.121. VTK_THETA_M(VTK, PHASE)
11.1.13.122. VTK_SCALAR(VTK, SCALAR)
11.1.13.123. VTK_RRATE(VTK, RATE)
  • \(1 \le rate \le nRRmax\)
11.1.13.124. VTK_RRATE_LABEL(VTK, RATE)
11.1.13.125. VTK_FLUID_RRATE(VTK, RATE)
11.1.13.126. VTK_DES_RRATE(VTK, RATE)
Write Lagrangian (DEM, CGDEM, PIC) reaction rates in region. Particle/parcel data is
accumulated in fluid cells.
11.1.13.127. VTK_K_TURB_G(VTK)
11.1.13.128. VTK_E_TURB_G(VTK)
11.1.13.129. VTK_VORTICITY(VTK)
11.1.13.130. VTK_LAMBDA_2(VTK)
Write lambda_2 in region.
11.1.13.131. VTK_PARTITION(VTK)
11.1.13.132. VTK_BC_ID(VTK)
11.1.13.133. VTK_DWALL(VTK)
11.1.13.134. VTK_FACET_COUNT_DES(VTK)
11.1.13.135. VTK_NB_FACET_DES(VTK)
11.1.13.136. VTK_IJK(VTK)
11.1.13.137. VTK_NORMAL(VTK)
11.1.13.138. VTK_DEBUG(VTK, IDX)
  • \(1 \le IDX \le 15\)
11.1.13.139. VTK_PART_DIAMETER(VTK)
11.1.13.140. VTK_PART_PHYSICAL_DIAMETER(VTK)
11.1.13.141. VTK_PART_CGP_STAT_WT(VTK)
11.1.13.142. VTK_PART_VEL(VTK)
11.1.13.143. VTK_PART_ANGULAR_VEL(VTK)
11.1.13.144. VTK_PART_ORIENTATION(VTK)
11.1.13.145. VTK_PART_USR_VAR(VTK, USR_VAR)
11.1.13.146. VTK_PART_TEMP(VTK)
11.1.13.147. VTK_PART_X_S(VTK, DES_SPECIES)
11.1.13.148. VTK_PART_RRATE(VTK, RATE)
11.1.13.149. VTK_PART_DENSITY(VTK)
11.1.13.150. VTK_PART_COHESION(VTK)
11.1.13.151. VTK_PART_RANK(VTK)
11.1.13.152. VTK_PART_ID(VTK)
Write particle ID in region.
11.1.13.153. VTK_PART_RESIDENCE_TIME(VTK)
11.1.13.154. VTK_PART_PHASE_ID(VTK)
11.1.13.155. VTK_PART_PHASE(VTK, PHASE)
11.1.13.156. VTK_FCMAX_ONLY(VTK)
11.1.13.157. VTK_PART_COL_FORCE(VTK)
11.1.13.158. VTK_CUTCELL_ONLY(VTK)
11.1.13.159. FRAME(VTK)
11.1.13.160. VTU_DIR
Directory where VTK files are stored. By default,
11.1.13.161. DES_REPORT_MASS_INTERP
11.1.13.163. VTP_DIR
11.1.13.164. DES_OUTPUT_TYPE
Table 11.64 Valid Values
PARAVIEW
TECPLOT
11.1.13.165. DEBUG_DES
11.1.13.166. FOCUS_PARTICLE
11.1.13.167. WRITE_PART_OUT
11.1.13.168. PART_OUT_ZERO_VEL
11.1.13.169. PART_OUT_X_MIN
11.1.13.170. PART_OUT_X_MAX
11.1.13.171. PART_OUT_X_EXCLUDE
11.1.13.172. PART_OUT_Y_MIN
11.1.13.173. PART_OUT_Y_MAX
11.1.13.174. PART_OUT_Y_EXCLUDE
11.1.13.175. PART_OUT_Z_MIN
11.1.13.176. PART_OUT_Z_MAX
11.1.13.177. PART_OUT_Z_EXCLUDE
11.1.13.178. PART_OUT_PHASE(PHASE)
11.1.13.179. PART_OUT_DIAMETER_MIN
11.1.13.180. PART_OUT_DIAMETER_MAX
11.1.13.181. PART_OUT_DIAMETER_EXCLUDE
11.1.13.182. PART_OUT_DENSITY_MIN
11.1.13.183. PART_OUT_DENSITY_MAX
11.1.13.184. PART_OUT_DENSITY_EXCLUDE
11.1.13.185. PART_OUT_U_MIN
11.1.13.186. PART_OUT_U_MAX
11.1.13.187. PART_OUT_U_EXCLUDE
11.1.13.188. PART_OUT_V_MIN
11.1.13.189. PART_OUT_V_MAX
11.1.13.190. PART_OUT_V_EXCLUDE
11.1.13.191. PART_OUT_W_MIN
11.1.13.192. PART_OUT_W_MAX
11.1.13.193. PART_OUT_W_EXCLUDE
11.1.13.194. PART_OUT_TEMP_MIN
11.1.13.195. PART_OUT_TEMP_MAX
11.1.13.196. PART_OUT_TEMP_EXCLUDE
11.1.13.197. PART_OUT_X_S_MIN(INDEX)
  • \(1 \le Index \le 100\)
11.1.13.198. PART_OUT_X_S_MAX(INDEX)
11.1.13.199. PART_OUT_X_S_EXCLUDE(INDEX)
11.1.13.200. PART_OUT_USR_VAR_MIN(INDEX)
11.1.13.201. PART_OUT_USR_VAR_MAX(INDEX)
11.1.13.202. PART_OUT_USR_VAR_EXCLUDE(INDEX)
11.1.13.203. PART_IN_X_MIN
11.1.13.204. PART_IN_X_MAX
11.1.13.205. PART_IN_X_EXCLUDE
11.1.13.206. PART_IN_Y_MIN
11.1.13.207. PART_IN_Y_MAX
11.1.13.208. PART_IN_Y_EXCLUDE
11.1.13.209. PART_IN_Z_MIN
11.1.13.210. PART_IN_Z_MAX
11.1.13.211. PART_IN_Z_EXCLUDE
11.1.13.212. PART_IN_PHASE(PHASE)
11.1.13.213. PART_IN_DIAMETER_MIN
11.1.13.214. PART_IN_DIAMETER_MAX
11.1.13.215. PART_IN_DIAMETER_EXCLUDE
11.1.13.216. PART_IN_DENSITY_MIN
11.1.13.217. PART_IN_DENSITY_MAX
11.1.13.218. PART_IN_DENSITY_EXCLUDE
11.1.13.219. PART_IN_U_MIN
11.1.13.220. PART_IN_U_MAX
11.1.13.221. PART_IN_U_EXCLUDE
11.1.13.222. PART_IN_V_MIN
11.1.13.223. PART_IN_V_MAX
11.1.13.224. PART_IN_V_EXCLUDE
11.1.13.225. PART_IN_W_MIN
11.1.13.226. PART_IN_W_MAX
11.1.13.227. PART_IN_W_EXCLUDE
11.1.13.228. PART_IN_TEMP_MIN
11.1.13.229. PART_IN_TEMP_MAX
11.1.13.230. PART_IN_TEMP_EXCLUDE
11.1.13.231. PART_IN_X_S_MIN(INDEX)
11.1.13.232. PART_IN_X_S_MAX(INDEX)
11.1.13.233. PART_IN_X_S_EXCLUDE(INDEX)
11.1.13.234. PART_IN_USR_VAR_MIN(INDEX)
11.1.13.235. PART_IN_USR_VAR_MAX(INDEX)
11.1.13.236. PART_IN_USR_VAR_EXCLUDE(INDEX)
