3.8. SMS meshing workflow, cyclone, Discrete Element Model (DEM)¶
The SMS workflow is currently available as a beta testing feature, and can
be turned on from the settings menu (select SMS: Segregated Mesher/Solver (beta)
from the Mesher workflow drop down list). The blank
template will automatically
3.8.1. Create a new project¶
3.8.2. Import the geometry¶
Go to the Geometry
Choose
STL file
cyclone.stl
, select it and answerYes
when prompted to copy the file to the project directory.Verify the STL normals are pointing in the right direction. In the model window, show the Geometry, hide the Background mesh, hide the Regions (visibility is toggled by clicking on each icon). Set the Geometry style to
edges
, opacity to 1.0, check theShow normals
box, set theScale
to 0.05, setcount
to 10,000 (to show all normals).
Check the Flip normals
box and notice the difference in the Model view. Uncheck the box since the original STL
file was correctly oriented.
In
Domain extent
, click on Autosize, and adjust the following:Enter
0.0
for the Min Y value.Enter
0.9
for the Max Y value.Enter
0.25
for the Max Z value.
3.8.3. Create boundary conditions regions¶
Go to the Regions
There is already a
Background IC
that is predefined in the Blank template. We can ignore it for now.Click the
(top) button to create a new region to be used by pressure outflow boundary condition.
Pressure outflow
in theBoundary type
drop down menu.Enter a name for the region in the
field (“Top outlet”).Change the region color to blue.
(bottom) button to create a new region to be used by another pressure outflow boundary condition.
Pressure outflow
in theBoundary type
field (“Bottom outlet”).Change the region color to yellow.
(front) button to create a new region to be used by mass inflow boundary condition.
Mass inflow
in theBoundary type
field (“Front inlet”).Change the region color to red.
No-slip wall
in theBoundary type
field (“Wall”).Change the region color to green.
Select facets (STL)
andcyclone.stl
, useall
for the selection method. You should see that there are 7554 facets selected.
3.8.4. Setup the mesh¶
Go to the Mesh
pane, Background
25
for the x cell value.Enter
70
for the y cell value.Enter
33
for the z cell value.
Go to the Mesh
pane, Mesher
Generate
. Select the default solver, and clickRun
Look at the console output to verify the mesh generation completed successfully.
In the Model view - hide the
Geometry
,Background mesh
andRegions
, - show theBoundary mesh
- setColor by
tobc_id
, - setStyle
toedges
and opacity to1.0
.The boundary mesh should look like a closed surface with colors matching the boundary conditions regions.
Color the boundary mesh by
small_cell
. This will show small cells, as defined by the small cell tolerance. The default value of 0.01 means a cut cell is considered small if its volume is below 0.01 times the volume of the corresponding standard, uncut cell. These small cells will be removed from the computation. Having a Small cell tolerance set to 0.0 will keep all small cells and this may lead to numerical stiffness and loss of convergence.
Mesh statistics (histogram) can be viewed in the Mesh stats viewport. Various quantities are available. For example the aspect ratio of cut cells is between 1 and 8, with most aspect ratios between 1 and 2. This is acceptable.
After inspection, the mesh is deemed acceptable and we can move to the second step (Solver mode). Click Accept
. This will unlock the Modeler tab.
Go back to the
Geometry
pane, and flip the normals. This will incorrectly orient the STL file. This is a common error when importing STL files. Generate the mesh and visualize the boundary mesh. Having an open surface and boundaries inside-out is an indication that the normals are not properly oriented. The mesh should not be accepted.
Uncheck the
Flip normals
box in the Geometry pane to get correct orientation. Go to the Region pane, and select the Front inlet region in the region table and set theBoundary type
toNone
. Save the project and generate the mesh. The boundary mesh will look like an open surface, this is an indication a boundary condition is missing. The mesh should not be accepted.
Remember to set the Front inlet region boundary type to Mass inflow
again before continuing.
3.8.5. Model settings¶
Model
field.Select “Discrete Element Model (MFiX-DEM)” in the
drop-down menu.Keep all other settings at their default values.
3.8.6. Regions settings¶
We already have the Background_IC region that is predefined. We will use it to initialize the flow field. We have defined all Boundary Condition regions during the meshing step. There are no other regions that need to be defined in this tutorial. We will reuse Background_IC region for the VTK output file.
3.8.7. Fluid settings¶
Change Density to
Ideal gas law
3.8.8. Solids settings¶
pane, Materials
field (“Glass beads”).Verify the solids model is already set to “Discrete Element Model (MFiX-DEM)”.
0.005
field.Enter the particle density of
2500
kg/m3 in theDensity
field.
Solids
pane,DEM
sub-pane.Check the
checkbox. Although we will start with an empty cyclone, this setting is necessary so we don’t attempt to read initial particle location fromparticle_input.dat
3.8.9. Initial Conditions settings¶
There is already a pre-defined “Background IC” region. This will initialize the entire flow field with air at rest.
3.8.10. Boundary Conditions settings¶
The Top outlet and Bottom outlet Boundary Conditions are already set to atmospheric pressure. No changes are needed.
3.8.11. Numerics settings¶
On the Numerics
3.8.12. Output settings¶
checkbox.
sub-pane.Select “Particle Data” from the ‘Output type’ drop-down menu.
to create the output.
*.vtu
files in theFilename base
field (“Particles”).Change the
to0.01
seconds.Select the
Diameter
andTranslational Velocity
checkboxes.
3.8.13. Run settings¶
Set
Stop time
to1.0
.Set
to0.01
.Set
to0.01
3.8.14. Run the simulation¶
Run
dialog, select the executable from the combo-box.Click the
Run
button to actually start the simulation.
3.8.15. View results¶
next to the Model tab.
3D view
