5.1.2. Custom solver from command line¶
default solver.
$ ls
$ build_mfixsolver
...build output...
$ ls
build/ lib/ mfixsolver mfixsolver.so SP2D.mfx usr0.f usr0.o usr1.f usr_mod.f usr_rates.f
mfixsolver, that runs the case-specific MFiX solver (mfixsolver.so).
build_mfixsolver again.
