5.3. Build from source (for developers)¶
5.3.1. Obtaining MFiX source¶
(bash)$ tar xf mfix-24.4.tar.gz
(bash)$ cd mfix-24.4
(bash)$ pwd
/home/user/mfix-24.4
Folder |
model |
postmfix |
Source code for the post-processing tool postmfix |
queue_templates |
tutorials |
tests |
legacy_tutorials |
legacy_tests |
The source code is also available from the GUI, from the “Editor” tab. Files are located in the “MFiX source” file explorer. Selecting a file will open it in the editor. Users wishing to modify the source code should copy a file to the project directory. This is accomplished automatically by clicking “Copy” when prompted “Copy to project directory for editing?”
It is recommended to study the simulations files in the “tutorials” folder. These simulations can be loaded in the GUI from Main menu>New project. Interested users can study files located in the legacy_tutorials and legacy_tests folders. However, these are provided as examples that are compatible with older versions of MFiX (2016-1 and prior).
5.3.3. Building solver from source¶
You can build the Batch solver from source, without the MFiX Conda package installed. This is how MFiX was built in version 2016 and earlier.
You will need a Fortran compiler, GNU Make and CMake version 3.16 or newer. Note that the MFiX Conda package provides all of these, so if you do not use Conda, you have to use your system package manager to install these prerequisites. The MFiX team does not provide support for this option.
build issues to the forum.
5.3.3.1. Configuring¶
$ mkdir debug-build
$ cd debug-build
$ cmake .. -DCMAKE_BUILD_TYPE=Debug
$ mkdir release-build
$ cd release-build
$ cmake .. -DCMAKE_BUILD_TYPE=RelWithDebInfo -DENABLE_MPI=1
$ cmake .. # same thing (RelWithDebInfo is the default CMAKE_BUILD_TYPE)
$ mkdir debug-build
$ cd debug-build
$ cmake .. -DCMAKE_BUILD_TYPE=Debug -DENABLE_MPI=1
$ cmake .. -DCMAKE_Fortran_COMPILER=ifort # for example
$ cmake .. -DCMAKE_Fortran_FLAGS="-O0 -g -Wall -fcheck=all" # for example
$ cmake .. -ENABLE_OpenMP=ON
$ cmake .. -ENABLE_OpenMP=ON -DCMAKE_Fortran_COMPILER=ifort -DCMAKE_Fortran_FLAGS="-O0 -g -Wall -fcheck=all"
$ cmake .. -DENABLE_MPI=0 -DCMAKE_Fortran_COMPILER=gfortran -DCMAKE_Fortran_FLAGS="-O2 -g"
$ cmake .. -DENABLE_MPI=0 -DCMAKE_Fortran_COMPILER=gfortran -DCMAKE_Fortran_FLAGS="-march=native -O3"
$ cmake .. -DENABLE_MPI=1 -DMPI_Fortran_COMPILER=mpifort -DCMAKE_Fortran_FLAGS="-O2 -g"
$ cmake .. -DENABLE_MPI=0 -DCMAKE_Fortran_COMPILER=gfortran -DCMAKE_Fortran_FLAGS="-O0 -fcheck=all -g"
$ cmake .. -DENABLE_MPI=1 -DMPI_Fortran_COMPILER=mpifort -DCMAKE_Fortran_FLAGS="-O0 -fcheck=all -g"
compiler you intend to use.
with different options. The build_mfixsolver script removes CMakeCache.txt
each time it runs so old options are not reapplied.
5.3.3.2. Building¶
type man make at the prompt.
$ make
$ make -j # for parallel build jobs
$ make VERBOSE=1 # to view the full command lines used for compiling and linking
