12.1.5. Discrete element model (DEM)
12.1.5.1. Discrete Element - Common
12.1.5.1.1. DES_DIFFUSE_WIDTH
12.1.5.1.2. DES_EPG_CLIP
12.1.5.1.3. DES_EXPLICITLY_COUPLED
Enable/Disable explicit coupling of DEM solids and the fluid.
Table 12.20 Valid values
12.1.5.1.4. DES_INTERP_MEAN_FIELDS
Table 12.21 Valid values
12.1.5.1.5. DES_INTERP_ON
Table 12.22 Valid values
12.1.5.1.6. DES_INTERP_SCHEME
Table 12.23 Valid values
Do not use interpolation.
GARG_2012
SQUARE_DPVM
Divided particle volume method: Information is interpolated to/from a particle’s position using a square filter of size DES_INTERP_WIDTH.
LINEAR_HAT
Linear interpolation: Hat functions are used to distribute particle information. PIC only.
DPVM_SATELLITE
Divided particle volume method using satellites.
12.1.5.1.7. DES_INTERP_WIDTH
12.1.5.1.8. DES_INTG_METHOD
Time stepping scheme. Note that DEM solids species mass fraction always use firt-order Euler scheme regardless of this setting.
Table 12.24 Valid values
EULER
First-order Euler scheme.
ADAMS_BASHFORTH
Second-order ADAMS_BASHFORTH scheme. (DEM only)
12.1.5.1.9. DES_ONEWAY_COUPLED
Run one-way coupled simulations [default .FALSE.]. If set, the fluid does not see the particles in terms of drag force. The effect of particle volume is still felt by the fluid through non-unity voidage values.
Table 12.25 Valid values
12.1.5.1.10. DESGRIDSEARCH_IMAX
12.1.5.1.11. DESGRIDSEARCH_JMAX
12.1.5.1.12. DESGRIDSEARCH_KMAX
12.1.5.1.13. GENER_PART_CONFIG
Table 12.26 Valid values
Generate particle configuration based on the initial condition parameters. Data provided in the particle input file, if present, is ignored.
Particle position and velocity data are provided in the particle input file. A runtime error occurs if this file is not provided.
12.1.5.1.14. PART_IN_DENSITY_EXCLUDE
Density filter selection mode applied to particles read from particle input file. By default, particles with data between min and max value are selected. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.5.1.15. PART_IN_DENSITY_MAX
Density maximum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are selected, unless PART_IN_DENSITY_EXCLUDE is set to .TRUE.
12.1.5.1.16. PART_IN_DENSITY_MIN
Density minimum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are selected, unless PART_IN_DENSITY_EXCLUDE is set to .TRUE.
12.1.5.1.17. PART_IN_DIAMETER_EXCLUDE
Diameter filter selection mode applied to particles read from particle input file. By default, particles with data between min and max value are selected. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.5.1.18. PART_IN_DIAMETER_MAX
Diameter maximum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are selected, unless PART_IN_DIAMETER_EXCLUDE is set to .TRUE.
12.1.5.1.19. PART_IN_DIAMETER_MIN
Diameter minimum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are selected, unless PART_IN_DIAMETER_EXCLUDE is set to .TRUE.
12.1.5.1.20. PART_IN_PHASE(PHASE)
Solids phase filter applied to particles read from particle input file. Change to .FALSE. to exclude particles belonging to this phase.
12.1.5.1.21. PART_IN_TEMP_EXCLUDE
Temperature filter selection mode applied to particles read from particle input file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.5.1.22. PART_IN_TEMP_MAX
Temperature maximum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are written out, unless PART_IN_TEMP_EXCLUDE is set to .TRUE.
12.1.5.1.23. PART_IN_TEMP_MIN
Temperature minimum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are written out, unless PART_IN_TEMP_EXCLUDE is set to .TRUE.
12.1.5.1.24. PART_IN_U_EXCLUDE
X-velocity filter selection mode applied to particles read from particle input file. By default, particles with data between min and max value are selected. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.5.1.25. PART_IN_U_MAX
X-velocity maximum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are selected, unless PART_IN_U_EXCLUDE is set to .TRUE.
12.1.5.1.26. PART_IN_U_MIN
X-velocity minimum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are selected, unless PART_IN_U_EXCLUDE is set to .TRUE.
12.1.5.1.27. PART_IN_USR_VAR_EXCLUDE(INDEX)
  • \(1 \le Index \le 100\)
User-defined variable filter selection mode applied to particles read from particle input file. By default, particles with data between min and max value are selected. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.5.1.28. PART_IN_USR_VAR_MAX(INDEX)
User-defined variable maximum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are written out, unless corresponding PART_IN_USR_VAR_EXCLUDE is set to .TRUE.
12.1.5.1.29. PART_IN_USR_VAR_MIN(INDEX)
User-defined variable minimum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are written out, unless corresponding PART_IN_USR_VAR_EXCLUDE is set to .TRUE.
12.1.5.1.30. PART_IN_V_EXCLUDE
Y-velocity filter selection mode applied to particles read from particle input file. By default, particles with data between min and max value are selected. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.5.1.31. PART_IN_V_MAX
Y-velocity maximum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are selected, unless PART_IN_V_EXCLUDE is set to .TRUE.
12.1.5.1.32. PART_IN_V_MIN
Y-velocity minimum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are selected, unless PART_IN_V_EXCLUDE is set to .TRUE.
12.1.5.1.33. PART_IN_W_EXCLUDE
Z-velocity filter selection mode applied to particles read from particle input file. By default, particles with data between min and max value are selected. out. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.5.1.34. PART_IN_W_MAX
Z-velocity maximum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are selected, unless PART_IN_W_EXCLUDE is set to .TRUE.
12.1.5.1.35. PART_IN_W_MIN
Z-velocity minimum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are selected, unless PART_IN_W_EXCLUDE is set to .TRUE.
12.1.5.1.36. PART_IN_X_EXCLUDE
X-coordinate filter selection mode applied to particles read from particle input file. By default, particles with data between min and max value are selected. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.5.1.37. PART_IN_X_MAX
X-coordinate maximum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are selected, unless PART_IN_X_EXCLUDE is set to .TRUE.
12.1.5.1.38. PART_IN_X_MIN
X-coordinate minimum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are selected, unless PART_IN_X_EXCLUDE is set to .TRUE.
12.1.5.1.39. PART_IN_X_S_EXCLUDE(INDEX)
Species filter selection mode applied to particles read from particle input file. By default, particles with data between min and max value are selected and written out. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.5.1.40. PART_IN_X_S_MAX(INDEX)
Species maximum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are written out, unless corresponding PART_IN_X_S_EXCLUDE is set to .TRUE.
12.1.5.1.41. PART_IN_X_S_MIN(INDEX)
Species minimum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are written out, unless corresponding PART_IN_X_S_EXCLUDE is set to .TRUE.
12.1.5.1.42. PART_IN_Y_EXCLUDE
Y-coordinate filter selection mode applied to particles read from particle input file. By default, particles with data between min and max value are selected. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.5.1.43. PART_IN_Y_MAX
Y-coordinate maximum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are selected, unless PART_IN_Y_EXCLUDE is set to .TRUE.
12.1.5.1.44. PART_IN_Y_MIN
Y-coordinate minimum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are written out, unless PART_IN_Y_EXCLUDE is set to .TRUE.
12.1.5.1.45. PART_IN_Z_EXCLUDE
Z-coordinate filter selection mode applied to particles read from particle input file. By default, particles with data between min and max value are selected. Change to .TRUE. to select particles with data outside the [min;max] range.
12.1.5.1.46. PART_IN_Z_MAX
Z-coordinate maximum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are selected, unless PART_IN_Z_EXCLUDE is set to .TRUE.
12.1.5.1.47. PART_IN_Z_MIN
Z-coordinate minimum value of the filter applied to particles read from particle input file. By default, particles with data between min and max value are selected, unless PART_IN_Z_EXCLUDE is set to .TRUE.
12.1.5.1.48. PARTICLES
Number of particles to be read in from the particle input file. This value is ignored when using automatic particle generation. If unset, read all particles from file. A simulation with a mass inflow BC can start without solids by setting PARTICLES = 0.
12.1.5.2. Discrete Element Model
12.1.5.2.1. ASPERITIES
12.1.5.2.2. DES_BUFF_RESIZE_FACTOR
12.1.5.2.3. DES_COLL_MODEL
Table 12.27 Valid values
LSD
HERTZIAN
The Hertzian model. Requires: DES_ET_INPUT, DES_ET_WALL_INPUT, E_YOUNG, EW_YOUNG, V_POISSON, VW_POISSON.
12.1.5.2.4. DES_CONV_CORR
Table 12.28 Valid values
RANZ_1952
GUNN
WAKAO
TAVASSOLI
12.1.5.2.5. DES_EM(PHASE)
Emissivity of solids phase.
12.1.5.2.6. DES_EN_INPUT(INDEX)
12.1.5.2.7. DES_EN_WALL_INPUT(INDEX)
  • \(1 \le Index \le MMAX\)
12.1.5.2.8. DES_ET_INPUT(INDEX)
12.1.5.2.9. DES_ET_WALL_INPUT(INDEX)
12.1.5.2.10. DES_ETAT_FAC
Table 12.29 Valid values
UNDEFINED
12.1.5.2.11. DES_ETAT_W_FAC
Table 12.30 Valid values
UNDEFINED
12.1.5.2.12. DES_MIN_COND_DIST
12.1.5.2.14. DLB_DT
Table 12.32 Valid values
UNDEFINED
>0
12.1.5.2.15. DLB_EGW
Table 12.33 Valid values
>=0
12.1.5.2.16. DTSOLID
Solids time step (s). If this value is left blank (UNDEFINED), then it will be automatically computed based on particle properties, and DTSOLID_FACTOR.
12.1.5.2.17. DTSOLID_FACTOR
Ratio between the collision time and the solids time step (default value is 50). Minimum value is 10.0. It is highly recommended to keep the default value.
12.1.5.2.18. DTSOLID_UPDATE_DT
12.1.5.2.19. E_YOUNG(PHASE)
12.1.5.2.20. E_YOUNG_ACTUAL(PHASE)
12.1.5.2.21. EW_YOUNG
12.1.5.2.22. EW_YOUNG_ACTUAL
12.1.5.2.23. FACTOR_RLM
12.1.5.2.24. FLPC
12.1.5.2.25. HAMAKER_CONSTANT
12.1.5.2.26. KN
12.1.5.2.27. KN_W
12.1.5.2.28. KT_FAC
12.1.5.2.29. KT_W_FAC
12.1.5.2.30. MEW
12.1.5.2.31. MEW_R
12.1.5.2.32. MEW_RW
12.1.5.2.33. MEW_W
12.1.5.2.34. MINIMIZE_DES_FACET_LIST
12.1.5.2.35. NEIGHBOR_SEARCH_N
12.1.5.2.36. NEIGHBOR_SEARCH_RAD_RATIO
12.1.5.2.37. NFACTOR
12.1.5.2.38. REMOVE_ROGUE_PARTICLES
12.1.5.2.39. USE_COHESION
12.1.5.2.40. USE_VDH_DEM_MODEL
12.1.5.2.41. V_POISSON(PHASE)
12.1.5.2.42. V_POISSON_ACTUAL(PHASE)
12.1.5.2.43. VAN_DER_WAALS
12.1.5.2.44. VDW_INNER_CUTOFF
12.1.5.2.45. VDW_OUTER_CUTOFF
12.1.5.2.46. VW_POISSON
12.1.5.2.47. VW_POISSON_ACTUAL
12.1.5.2.48. WALL_HAMAKER_CONSTANT
12.1.5.2.49. WALL_VDW_INNER_CUTOFF
12.1.5.2.50. WALL_VDW_OUTER_CUTOFF
12.1.5.3. Particles in Cell
12.1.5.3.1. FRIC_EXP_PIC
12.1.5.3.2. FRIC_NON_SING_FAC
12.1.5.3.3. MPPIC_COEFF_EN1
12.1.5.3.4. MPPIC_COEFF_EN_WALL
12.1.5.3.5. MPPIC_COEFF_ET_WALL
12.1.5.3.6. MPPIC_VELFAC_COEFF
12.1.5.3.7. PIC_CD_E
12.1.5.3.8. PIC_CFL
12.1.5.3.9. PIC_CFL_CONTROL
12.1.5.3.10. PIC_CFL_PARCEL_FRACTION
12.1.5.3.11. PIC_COLLISION_DAMPING
12.1.5.3.12. PSFAC_FRIC_PIC
