12.1.8. Initial conditions (IC)
Each initial condition is specified over a rectangular region (or pie-shaped for cylindrical coordinates) that corresponds to the scalar numerical grid. These are 3D regions: X_w X_e, Y_s Y_n, and Z_t Z_b. The region is defined by the constant coordinates of each of the six faces, which may be specified as the physical coordinates or the cell indices. The physical coordinates are easier to specify than the cell indices. If cell sizes are not small enough to resolve a region specified using physical coordinates, MFIX will indicate this problem with an error message.
12.1.8.1. IC_DES_ABORT_ON_FAILED_SEEDING(IC, PHASE)
  • \(1 \le IC \le 500\)
Flag to abort if unsuccessful seeding occurs.
12.1.8.2. IC_DES_LATTICE(IC, PHASE)
Type of initial lattice distribution (simple cubic or hexagonal) to the entire IC region.
Table 12.49 Valid values
HEXA
Particles are distributed on a hexagonal close-packed lattice.
CUBIC
Particles are distributed on a cubical lattice.
12.1.8.3. IC_DES_NP(IC, PHASE)
12.1.8.4. IC_DES_RAND(IC, PHASE)
12.1.8.5. IC_DES_RAND_FACTOR_X(IC, PHASE)
12.1.8.6. IC_DES_RAND_FACTOR_Y(IC, PHASE)
12.1.8.7. IC_DES_RAND_FACTOR_Z(IC, PHASE)
12.1.8.8. IC_DES_SM(IC, PHASE)
12.1.8.9. IC_DES_SPACE_FACTOR_X(IC, PHASE)
12.1.8.10. IC_DES_SPACE_FACTOR_Y(IC, PHASE)
12.1.8.11. IC_DES_SPACE_FACTOR_Z(IC, PHASE)
12.1.8.12. IC_DES_SPACING(IC, PHASE)
Spacing between particle within initial lattice distribution (expressed as a fraction of particle diameter) to the entire IC region.
12.1.8.13. IC_E_TURB_G(IC)
12.1.8.14. IC_EP_G(IC)
12.1.8.15. IC_EP_S(IC, PHASE)
12.1.8.16. IC_GAMA_RG(IC)
Gas phase radiation coefficient in the IC region. Modify file energy_mod.f to change the source term.
12.1.8.17. IC_GAMA_RS(IC, PHASE)
12.1.8.18. IC_GSP_RANDOM_Q(IC, PHASE)
Initialize GSP with random orientation (quaternion) in the IC region.
12.1.8.19. IC_I_E(IC)
12.1.8.20. IC_I_W(IC)
12.1.8.21. IC_J_N(IC)
12.1.8.22. IC_J_S(IC)
12.1.8.23. IC_K_B(IC)
12.1.8.24. IC_K_T(IC)
K index of the top-most wall.
12.1.8.25. IC_K_TURB_G(IC)
12.1.8.26. IC_L_SCALE(IC)
12.1.8.27. IC_OVERRIDE_PART_INPUT(IC, PHASE)
Initial conditions take precedence over data in particle_inpupt.dat file for this region and solids phase.
12.1.8.28. IC_P_G(IC)
12.1.8.29. IC_P_STAR(IC)
12.1.8.30. IC_PIC_CONST_STATWT(IC, PHASE)
Flag to specify the initial constant statistical weight for computational particles/parcels. Actual number of parcels will be automatically computed.
12.1.8.31. IC_PSD_MAX_DP(IC, PHASE)
12.1.8.32. IC_PSD_MEAN_DP(IC, PHASE)
Initial mean value of particle size distribution of solids phase in the IC region. For a log-normal psd, The mean diameter (µ) and standard deviation (𝜎) will be used to compute the log-normal parameters µ_ln and 𝜎_ln : µ_ln = ln(µ²/√(µ² + 𝜎²)) and 𝜎_ln = √(ln(1 + (𝜎/µ)²)))
12.1.8.33. IC_PSD_MIN_DP(IC, PHASE)
12.1.8.34. IC_PSD_STDEV(IC, PHASE)
Initial standard deviation of particle size distribution of solids phase in the IC region. For a log-normal psd, The mean diameter (µ) and standard deviation (𝜎) will be used to compute the log-normal parameters µ_ln and 𝜎_ln : µ_ln = ln(µ²/√(µ² + 𝜎²)) and 𝜎_ln = √(ln(1 + (𝜎/µ)²)))
12.1.8.35. IC_PSD_TYPE(IC, PHASE)
Table 12.50 Valid values
MONO
Uniform particle size.
NORMAL
LOG_NORMAL
CUSTOM
12.1.8.36. IC_ROP_S(IC, PHASE)
12.1.8.37. IC_SCALAR(IC, SCALAR EQ.)
12.1.8.38. IC_SQP_RANDOM_Q(IC, PHASE)
12.1.8.39. IC_T_G(IC)
12.1.8.40. IC_T_RG(IC)
12.1.8.41. IC_T_RS(IC, PHASE)
12.1.8.42. IC_T_S(IC, PHASE)
12.1.8.43. IC_THETA_M(IC, PHASE)
12.1.8.44. IC_TYPE(IC)
12.1.8.45. IC_U_G(IC)
Initial x-axial component of gas velocity in the IC region.
12.1.8.46. IC_U_S(IC, PHASE)
Initial x-axial component of solids-phase velocity in the IC region.
12.1.8.47. IC_V_G(IC)
Initial y-axial component of gas velocity in the IC region.
12.1.8.48. IC_V_S(IC, PHASE)
Initial y-axial component of solids-phase velocity in the IC region.
12.1.8.49. IC_W_G(IC)
Initial z-axial component of gas velocity in the IC region.
12.1.8.50. IC_W_S(IC, PHASE)
Initial z-axial component of solids-phase velocity in the IC region.
12.1.8.51. IC_X_E(IC)
12.1.8.52. IC_X_G(IC, SPECIES)
  • \(1 \le Species \le 100\)
12.1.8.53. IC_X_S(IC, PHASE, SPECIES)
12.1.8.54. IC_X_W(IC)
12.1.8.55. IC_Y_N(IC)
12.1.8.56. IC_Y_S(IC)
12.1.8.57. IC_Z_B(IC)
12.1.8.58. IC_Z_T(IC)
Z coordinate of the top face.
