12.1.6. Gas phase
12.1.6.1. ALPHA_TRANSPORT(SPECIES)
  • \(1 \le Species \le 100\)
The polarizability in transport data. [in cubic Angstroms].
12.1.6.2. C_PG0
12.1.6.3. CONFIG_TRANSPORT(SPECIES)
Geometrical configuration of molecule.
Table 12.34 Valid values
Monatomic
Linear
Nonlinear
12.1.6.4. DABG(SPECIES, SPECIES)
Set constant binary diffusion coefficients if known [m^2/s in SI]
12.1.6.5. DIF_COEFF_KT
Compute diffusion coefficients from kinetic theory.
Table 12.35 Valid values
Use constant diffusion coefficients. Diffusion data can be obtained from:
  • Taylor, R & Krishna, R, Multicomponent Mass Transfer, Wiley, 1993, p. 134.
Compute diffusion coefficients from kinetic theory. Parameters in Lennard-Jones intermolecular potential model can be obtained from:
  • Table E.1 in Transport Phenomena, by Bird-Stewart-Lightfoot, Wiley, 2002, p. 864.
  • Appendix E: Data. In Liquid-State Physical Chemistry https://doi.org/10.1002/9783527676750.app5
  • Appendix C in The Properties of Gases and Liquids by Reid-Prausnitz-Sherwood, McGraw-Hill, 1977, p. 678.
12.1.6.6. DIF_G0
12.1.6.7. DIF_THERMAL
Include thermal diffusion in multicomponent diffusion model.
Table 12.36 Valid values
Compute thermal diffusion.
Ignore effects of thermal diffusion.
12.1.6.8. HB_GAMA_C
Strain rate cutoff [1/s] in Herschel-Bulkley viscosity law.
12.1.6.9. HB_K0
Consistency factor [Pa.s^n] in Herschel-Bulkley viscosity law.
12.1.6.10. HB_N
  • Power law index (dimensionless) in Herschel-Bulkley viscosity law.
  • 0 < HB_n < 1 : Shear thinning fluid
  • HB_n = 1 : Bingham fluid
  • HB_n > 1 : Shear thickening fluid
12.1.6.11. HB_TAU0
Bingham yield stress [Pa] in Herschel-Bulkley viscosity law.
12.1.6.12. K_G0
12.1.6.13. KG_MODEL
Gas thermal conductivity model (default is temperature-dependent value for air).
Table 12.37 Valid values
CONSTANT
Constant thermal conductivity. K_g0 must be specified.
AIR
Temperature-dependent model for air
LENNARD_JONES
Lennard-Jones model. Bird, R., Stewart, W. and Lightfoot, E. (2002) Transport Phenomena.2nd Edition, John Wiley and Sons, New York. Eq.(9.3-13) on Page 275 for the calculation of thermal conductivity. Eq.(E.2-1) on Page 866 for the collision integral.
CANTERA_POLY
Polynomial fit from species transport data using cantera. https://cantera.org/dev/cxx/d8/d58/classCantera_1_1GasTransport.html#a267d20cdea7486fe84e722ee82d84b20
USR
User-defined function
12.1.6.14. LJEPS(SPECIES)
Epsilon/k coefficient in Lennard-Jones potential [in Kelvin].
12.1.6.15. LJSIG(SPECIES)
Sigma coefficient in Lennard-Jones potential [in Angstrom].
12.1.6.16. MU_G0
Specified constant gas viscosity [Pa.s in SI].
12.1.6.17. MU_G_MODEL
Gas viscosity model (default is Sutherland’s law).
Table 12.38 Valid values
CONSTANT
Constant viscosity
SUTHERLAND
Sutherland’s law
HERSCHEL-BULKLEY
Herschel-Bulkley (non-Newtonian) model
LENNARD_JONES
Lennard-Jones model. Bird, R., Stewart, W. and Lightfoot, E. (2002) Transport Phenomena.2nd Edition, John Wiley and Sons, New York. Eq.(1.4-14) on Page 26 for the calculation of viscosity. Eq.(E.2-1) on Page 866 for the collision integral.
CANTERA_POLY
USR
12.1.6.18. MU_TRANSPORT(SPECIES)
The dipole moment in transport data. [in Debye].
12.1.6.19. MULTI_COMPONENT_DIFFUSION
Solve the multicomponent diffusion model.
Table 12.39 Valid values
Include multicomponent diffusion model in species equation.
Do not include multicomponent diffusion model.
12.1.6.20. MW_AVG
12.1.6.21. MW_G(SPECIES)
12.1.6.22. NMAX_G
12.1.6.23. POLY_KG(SPECIES, INDEX)
  • \(1 \le Index \le 5\)
The fitted polynomial for species thermal conductivity from Cantera based on the transport data.
12.1.6.24. POLY_MU_G(SPECIES, INDEX)
The fitted polynomial for species viscosity from Cantera based on the transport data.
12.1.6.25. RO_G0
12.1.6.26. SL_MUREF
Reference gas viscosity [Pa.s in SI] in the Sutherland’s law.
12.1.6.27. SL_S
Sutherland constant [K] in the Sutherland’s law.
12.1.6.28. SL_TREF
Reference temperature [K] in the Sutherland’s law.
12.1.6.29. SPECIES_ALIAS_G(SPECIES)
12.1.6.30. SPECIES_G(SPECIES)
12.1.6.31. ZROT_TRANSPORT(SPECIES)
The rotational relaxation collision number at 298K. It is dimensionless.
