3.1. First tutorial¶
3.1.1. Starting the MFiX GUI¶
On Windows, open the Miniforge Prompt and activate the mfix environment
Windows
conda activate mfix-25.3
(mfix-25.3) C:\> mfix
Linux or Mac
(mfix-25.3) > mfix
3.1.2. Creating a project¶
(New)
Icon |
Single-phase Model |
Two-fluid Model (TFM) |
Hybrid Model (TFM + DEM) |
Chemistry |
(single-phase), and
(chemistry) icons
Double-click on
Click Ok
3.1.3. Running the solver¶
[default]/mfixsolver
The solver will begin to run, with output displayed in the Console window. There is a progress bar along the bottom of the screen where it says MFiX running: elapsed time.
3.1.4. View results¶
3.1.5. Pausing/unpausing¶
MFiX pausedwill be displayed in the Console window. The solver process still exists, but is waiting for you to unpause it.While the solver is paused, you can change the project. For instance, on the Run Pane you could change
3.1.6. Stopping/resuming¶
MFiX stopped will be displayed in the Console window. The solver
Clicking the
