3.3. Two-dimensional fluidized bed, Discrete Element Model (DEM)¶
15 cm x 90 cm x 0.4 cm |
15 x 45 x 1 |
2700 kg/m2 |
42.0 m/s |
3.3.1. Create a new project¶
Solverdrop-down menu.
3.3.3. Enter the geometry¶
0.15meters for the maximum x valueEnter
0.90meters for the maximum y valueEnter
0.004meters for the maximum z value
3.3.4. Enter the mesh¶
15for the x cell valueEnter
45for the y cell valueEnter
1for the z cell value
On the Regions pane:
Namefield (“bed”)Change the
To Yfield to be “ymax/2”Click the
Namefield (“inlet”)Enter
0.07in theFrom Xfield and0.08in theTo Xfield.Click the
Namefield (“outlet”)
3.3.6. Create a solid¶
Namefield (“solids”)Enter the particle diameter of
0.004m in theDiameterfieldEnter the particle density of
2700kg/m2 in theDensityfield
Solidspane,DEMsub-paneCheck the
Enable automatic particle generationcheckbox, so that the bed Initial Condition, defined later, will be filled with solidsSelect
No interpolationfor the Interpolation.
3.3.7. Create Initial conditions¶
OKbutton.
0.4in theVolume Fractionfield. This will fill the bottom half of the domain with solids.Note the estimated number of particles and inventory (around 3,200 particles or 0.3 kg). When running DEM simulations on a single core machine, it is recommended to stay below 100,000 particles to get reasonable run times.
3.3.8. Create Boundary conditions¶
Y-axial velocityfield of “42” m/s
3.3.9. Select output options¶
VTKsub-paneSelect “Particle Data” from the ‘Output type’ drop-down menu.
Select the “Background” region from the list to save all the particle data
OKto create the output
*.vtufiles in theFilename basefield (“particles”)Change the
DiameterandTranslational Velocitycheckboxes
Change
Stop timeto1.0secondsChange
Time stepto1e-2secondsChange
3.3.11. Run the project¶
Rundialog, select the executable from the combo-boxClick the
3.3.12. View results¶
