5.2. Building a Batch Solver
$ build_mfixsolver --batch
$ ls
build mfixsolver
This command will build an executable mfixsolver in the current directory.
The build directory can be deleted, and the custom mfixsolver will still
run. However, leaving the build directory will greatly speed up rebuilds if
you want to edit the UDFs and run build_mfixsolver again.
5.2.1. Configuration options
Arguments may be passed to build_mfixsolver to specify various options: compiler,
compiler flags, SMP/DMP support, and other options. All configuration options can
be displayed with:
$ build_mfixsolver --help
[FC=<Fortran compiler>]
[FCFLAGS=<Fortran flags>]
Argument |
Specify the Fortran compiler command |
Specify Fortran compiler flags |
Enable distributed memory support (MPI) |
Enable shared memory parallel support (OpenMP) |
The Fortran compiler is specified by passing the FC argument to
build_mfixsolver. If the FC argument is not specified, the script will
search the environment for a Fortran compiler (usually gfortran).
Compiler |
gfortran |
GNU Fortran compiler (serial/smp) |
ifort |
Intel Fortran compiler (serial/smp) |
mpif90 |
Generic MPI Fortran wrapper (dmp/combined smp-dmp) |
mpifort |
mpiifort |
Intel MPI Fortran wrapper (dmp/combined smp-dmp). Older versions commonly use the mpif90 command. |
Compiler flags can be specified by passing the FCFLAGS argument to
build_mfixsolver. If the FCFLAGS argument is not specified, the compiler
defaults are used.
GNU Fortran |
Intel Fortran |
Produce debugging information |
Generates runtime checks useful for debugging |
Print a full stack trace when a runtime error occurs |
Generates complete debugging information |
Generates optimized code for the local machine’s CPU. May not run on different machines. |
Running build_mfixsolver will display the flags specified with FCFLAGS,
and other compiler flags that are always defined by the build scripts:
-- Build type = RelWithDebInfo
-- Fortran compiler = /usr/bin/gfortran
-- Fortran flags = -Wall -cpp -ffree-line-length-0 -fconvert=big-endian -fPIC
The build_mfixsolver script will test specified Fortran compiler with any
specified flags (covered next). If the compiler is not found or if the compiler
doesn’t work with the specified flags, no Makefile will be generated and an
error message will be printed. When posting a question on the forum about build
issues, include any error messages.
5.2.2. Make options
build_mfixsolver will pass the options -j and -k on to make.
Building with -j on multicore systems will speed up the build process.
$ build_mfixsolver --batch -j
5.2.3. Building
To build the MFiX batch solver, run build_mfixsolver with the --batch option.
$ ls
...build output...
$ ls *
build mfixsolver SP2D.mfx usr0.f usr0.o usr1.f usr1.o usr_mod.f usr_mod.o usr_rates.f usr_rates.o
Note the absence of a lib directory. The lib directory has the Python
module for the interactive solver, and therefore is not present for a batch
solver. Also, mfixsolver is a binary executable (not a wrapper script).
To build the MFiX batch solver, with optimized code generated for the current CPU:
$ build_mfixsolver --batch FCFLAGS="-march=native -O3"
