5.3. Build from source (for developers)
5.3.1. Obtaining MFiX source
(bash)$ tar xf mfix-26.1.tar.gz
(bash)$ cd mfix-26.1
(bash)$ pwd
/home/user/mfix-26.1
5.3.2. Content of the MFiX source tarball
Folder
model
Source code for the MFiX solver
postmfix
Source code for the post-processing tool postmfix
queue_templates
Templates to submit jobs on HPC systems
tutorials
Examples of simulations ready to run from the GUI
tests
Simple simulations used for regression tests
legacy_tutorials
Old examples of simulations, meant to be run from command line
legacy_tests
Old tets cases meant to be run from command line
  1. The source code is also available from the GUI, from the “Editor” tab. Files are located in the “MFiX source” file explorer. Selecting a file will open it in the editor. Users wishing to modify the source code should copy a file to the project directory. This is accomplished automatically by clicking “Copy” when prompted “Copy to project directory for editing?”
  2. It is recommended to study the simulations files in the “tutorials” folder. These simulations can be loaded in the GUI from Main menu>New project. Interested users can study files located in the legacy_tutorials and legacy_tests folders. However, these are provided as examples that are compatible with older versions of MFiX (2016-1 and prior).
5.3.3. Building solver from source
You can build the Batch solver from source, without the MFiX Conda package installed. This is how MFiX was built in version 2016 and earlier.
You will need a Fortran compiler, GNU Make and CMake version 3.16 or newer. Note that the MFiX Conda package provides all of these, so if you do not use Conda, you have to use your system package manager to install these prerequisites. The MFiX team does not provide support for this option.
Running cmake will generate a CMakeCache.txt file in the directory it is invoked from. Please include CMakeCache.txt when posting a question about build issues to the forum.
5.3.3.1. Configuring
Using an “out of source” build is recommended. Create a new directory, cd to that directory, and run cmake <path> where <path> is the top-level MFiX source directory (containing CMakeLists.txt). Out of source builds are convenient for having different solvers built with different configurations. The build directory can be whatever you want; release-build and debug-build used here are just examples.
$ mkdir debug-build
$ cd debug-build
$ cmake .. -DCMAKE_BUILD_TYPE=Debug
$ mkdir release-build
$ cd release-build
$ cmake .. -DCMAKE_BUILD_TYPE=RelWithDebInfo -DENABLE_MPI=1
$ cmake .. # same thing (RelWithDebInfo is the default CMAKE_BUILD_TYPE)
$ mkdir debug-build
$ cd debug-build
$ cmake .. -DCMAKE_BUILD_TYPE=Debug -DENABLE_MPI=1
$ cmake .. -DCMAKE_Fortran_COMPILER=ifort  # for example
$ cmake .. -DCMAKE_Fortran_FLAGS="-O0 -g -Wall -fcheck=all"  # for example
$ cmake .. -ENABLE_OpenMP=ON
$ cmake .. -ENABLE_OpenMP=ON -DCMAKE_Fortran_COMPILER=ifort -DCMAKE_Fortran_FLAGS="-O0 -g -Wall -fcheck=all"
$ cmake .. -DENABLE_MPI=0 -DCMAKE_Fortran_COMPILER=gfortran -DCMAKE_Fortran_FLAGS="-O2 -g"
$ cmake .. -DENABLE_MPI=0 -DCMAKE_Fortran_COMPILER=gfortran -DCMAKE_Fortran_FLAGS="-march=native -O3"
$ cmake .. -DENABLE_MPI=1 -DMPI_Fortran_COMPILER=mpifort -DCMAKE_Fortran_FLAGS="-O2 -g"
$ cmake .. -DENABLE_MPI=0 -DCMAKE_Fortran_COMPILER=gfortran -DCMAKE_Fortran_FLAGS="-O0 -fcheck=all -g"
$ cmake .. -DENABLE_MPI=1 -DMPI_Fortran_COMPILER=mpifort -DCMAKE_Fortran_FLAGS="-O0 -fcheck=all -g"
For DMP support, defining -DENABLE_MPI=1 is required. Defining CMAKE_Fortran_COMPILER as your MPI wrapper (mpifort) is recommended, but not strictly required. CMake should automatically detect MPI include files and libraries for your default compiler, but specifying CMAKE_Fortran_COMPILER is better to ensure you are using the exact compiler you intend to use.
CMake uses configurations values from both CMakeCache.txt and from command line arguments. Command line arguments take precedence over CMakeCache.txt, but CMakeCache.txt is used if nothing is specified on the command line. For instance, if you run cmake .. -DCMAKE_Fortran_FLAGS="-fcheck=all", and then run cmake .. again (in the same build directory), -fcheck=all will still be used (because it is still in CMakeCache.txt). If this is not what you want, either edit CMakeCache.txt, or just delete CMakeCache.txt and run cmake again with different options. The build_mfixsolver script removes CMakeCache.txt each time it runs so old options are not reapplied.
5.3.3.2. Building
After configuring, build with make. For further details about the make utility, type man make at the prompt.
$ make
$ make -j        # for parallel build jobs
$ make VERBOSE=1 # to view the full command lines used for compiling and linking
At the end of a successful build, the MFiX solver will be located in the current directory. The solver is called mfixsolver on Linux.
