Ex. 2: Optimization¶
This example demonstrates the optimization of the Ackley function, which is commonly used to test the performance of optimization algorithms. The function has many local minima and one global minimum at \(f(0,0)=0\).
Populate the Nodes¶
The Node Wizard conveniently provides functionality to populate all the nodes and provides a collection of optimization test functions, including the Ackley function. To construct the workflow quickly and focus on the optimization aspect, use the wizard by:
Click on the
button to launch the wizard.
Click on the
Optimization
tab and set theFunction to be optimized
toAckley
and level theMethod
assurrogate
.Click
Populate Nodes
You should now have a collection of nodes including:
a Design of Experiments node with two variables, using the hammersly method with 1000 samples
a
Code
node with the Ackley functiona Response Surface node with the
radial basis function
selected, anda General Optimizer node
that looks like this:
Local Optimization¶
To demonstrate the challenge with black-box optimization, we will first try using a local minimization method:
On the General Optimizer, change the number of attempts to
.Select
local
from theMethod
combo-box. TheLocal Method
combo-box should appear with theNelder-Mead
method selected.Run all the nodes by pressing
button on the application toolbar.
After all the nodes have been run, the results of the 10 minimization attempts are displayed. Notice how each of the 10 attempts seems to provide a different “optimum”. This happens because each attempt has an initial condition which is randomly picked from inside the ranges of the variables specified in the Design of Experiments node. This local minimization method frequently gets stuck in the many local minima of the Ackley function.
The attempts can be visualized on the Plot
tab of the General Optimizer
node, where the surface is the sampled function and the dots are the
optimization attempts. Note how these particular attempts never found the global
minimum:
Global Optimization¶
Global optimization routines try to avoid getting stuck in local minima. One method provided in the General Optimizer node that works well is Differential Evolution.
To use this method:
select
differential evolution
from theMethod
combo-boxpress the
Optimize
button on the General Optimizer node
After the node has run, all 10 optimization attempts should be roughly the same value, \(f(-0.02, -0.02)=0.19\). The differential evolution algorithm did a good job of avoiding the local minimas and finding the true minimum. Unfortunately, this value is not precisely the true minimum, which should be \(f(0,0)=0\). The problem is that there are not enough samples at or around the true minimum for the surrogate model, constructed in the Response Surface, to accurately represent the sharp minimum of the Ackley function.
Response Surface Refinement¶
After an optimum has been found, the response surface can be refined around that optimum to get closer to the true optimum. In this particular case, lets see if we can get closer to the mathematical optimum. To do this, we will leave the original samples in-place and add new samples around the optimum:
Duplicate the Design of Experiments node and
Code
node bySelecting the Design of Experiments node by clicking on the title.
While holding
Ctrl
on the keyboard, select theCode
node by clicking on its title.Copy the selected nodes by either pressing
Ctrl
+c
on the keyboard orright-click
and selectCopy
from the menu.left-click
to the left of the Response Surface node.Paste the nodes by pressing
Ctrl
+v
and selectPaste
from the menu.
Add a
Matrix/Response
terminal to the Response Surface node by pressing thebutton below the existing
Matrix/Response
terminal.Connect the terminals of the copied nodes by
Connecting the
Selected Output
terminal of the copied Design of Experiments node to thematrix
terminal of the copiedCode
node.Connecting the
returnOut
terminals of the copiedCode
node to the newMatrix/Response 1
terminal of the Response Surface node.Connecting the
DOE Matrix
terminal of the copied Design of Experiments node to the newMatrix/Response 1
Adjust the variable ranges of the copied Design of Experiments node by
variable
tabSelect variable
a
and changed thefrom
value to-0.1
and theto
value to0.1
.Select variable
b
and changed thefrom
value to-0.1
and theto
value to0.1
.On the
Design
tab, change the number ofSamples
to100
.On the
Design
tab, press theBuild
button to build the samples.
Adjust the response surface in the Response Surface node node by
Model
tabSelect the
from the table.Change the
Function
frommultiquadric
tocubic
By adding the additional samples, the found optimum (\(f(-0.0007, 0.001)=0.02\)) is closer to the analytic solution (\(f(0,0)=0\)). You should have a workflow that looks like this:
See how close you can get to the true solution of \(f(0,0)=0\) by changing the samples and response surface model settings.
