When seeking help, please attach your project files. Use “Bug report” in the main menu to generate a .zip file containing all files needed to run your project as well as logs and diagnostic information.
Please search the forum before creating new topics. Repeated topics will be closed.
Do not add additional questions to a topic which has been marked “Solved”. Create a new topic.
If you are experiencing problems running a DMP or SMP simulation, try running the same project in serial mode.
If you have custom code (UDFs), try compiling the code with “Build type” set to “Debug”.
