Dear MFiX help,
I am planning to implement a particle agglomeration model on CFD-DEM results obtained from a MFiX-DEM simulation. Before implementing the model in MFiX, I would like to test its performance in another environment, e.g., MATLAB. In order to accomplish this, for the simplest model that we developed, I need to access to the following information:
• Particle ID, size & density
• DEM time step
• Center positions of particles at each DEM time step
• Velocities of particles at each DEM time step
Many of these information can be saved in the output .vtp files. However, I am not sure whether or not the writing interval can be adjusted as low as the DEM time step. When working with GUI, I feel that CFD time step has an impact on the writing interval for the saved DEM data (Output - Background IC - Particle data). Am I right?
According to the MFiX-DEM documentation, the DEM time step is calculated based on the values that we enter for the particle properties (size, density, normal spring constant, and dry restitution coefficient), DEM Δt = min(collision time/50). It will be nice to make sure that the DEM time step considered for the MFiX-DEM calculations matches with the value obtained from expressions provided in the MFiX-DEM documentation.
I do appreciate if you can advise me about the above-mentioned items and how I can access to the required information.
Thanks for your help, in advance.
Regards,
Jaber Shabanian
