I have encountered those two errors for my dem simulation with an stl geometry. I have checked similar topics, however the solutions provided didn’t help with my case. I’m using version 21.1.4 and I uploaded my project file. Can you kindly run and tell me what’s wrong with it? Here are the errors.
1st error:
Error 1100: No un-cut fluid cells adjacent to DEM_MI staging area.
Unable to setup the discrete solids mass inlet for BC: 1
Comment: BC 1 for me is the no slip wall of STL type. What can I do about this error? I have made my pseudo 2d (1 cell in Z-direction) domain similar to the “2d psuedo hopper tutorial”. I tried to extend the domain beyond the STL region but it didn’t work.
2nd error:
Error 1110: Solids velocity for BC 3 is too low to satisfy DEM
Comment: I have already used the specified mass flow rate in a similar 2d case and it worked. Is it because I’m using STL geometry?
Project file:
120_cone_2021-07-11T184201.880329.zip (175.8 KB)
Thanks,
