I have been able to run the Silane Pyrolysis case successfully and am working on something of my own.
My goal is to model the pseudo-first order adsorption of a gas into the solid phase. I started by just using a 0th order model but this did not seem to work as I received the following:
No computations seemed to have occurred. If anyone can offer any help as to what I may have missed I would really appreciate it. Thanks! Attached are my rates and mfx files.
Bump. Really hoping someone could help out with this. Maybe it is my solver? MFix has been great thus far and it would be disappointing if I couldn’t continue using it to incorporate chemical reactions.
Jeff is correct. It seems that you don’t have to open Energy equation when you simulate Chemical Reactions. However, when you want to use Stiff solver, you still needs to open ENERGY equations, otherwise GUI will report an error.
Thank you both very much! Your suggestions/comments have been of great help.
After making the corrections you both suggested the simulation does run. However looking at the results it seems like no reaction is occurring. The fraction of Solid A does not decrease as time goes on.
I have defined my reaction with CO2 being in the gas phase and Solid A being in the solid phase.
Is this preventing MFix from carrying out this reaction? My workaround would be determine some kind of mass transfer coefficient to bring the CO2 into a pseudo solid phase to react with Solid A. What do you think?
