Binary DEM data
Hi all,
I would like to write particle data in binary instead of ascii format and found several subroutines but I could not found any switch to decide wheather I want to write in binary or ascii format. How to do this or is it possible at all with the current version?
Thanks in advance!
Best Regards
Stephan
In the Output pane, if you check the "Write VTK output files (VTU/VTP), then it will write binary vtu or vtp files (go to the VTK tab to select regions and variables to write). The ASCII DES data can be turned on in the SPx tab: Write ASCII particle data.
Great. Thanks for the hint!
Always nice to work with the right software!
Best Regards
Stephan
