Building and Running MFIX-Exa on an ubuntu laptop
Notes
  • These are not the advised, recommended or even suggested build instructions.
    I am simply reporting what worked for me, on my laptop, running
    Ubuntu 22.04.4 LTS (Jammy Jellyfish).
  • I think these are all of the packages that I am using that are required to follow along:
    sudo apt-get update
    sudo apt-get install -y make cmake
    sudo apt-get install -y make cmake git-all
    sudo apt-get install -y gcc g++ gfortran
    sudo apt-get install -y build-essential libopenmpi-dev openmpi-bin
    sudo apt-get install -y m4
    sudo apt-get install -y vim
  • I’m doing this in a quad core laptop, so all make’s are with -j2. If you have more resources available, use them.
  • I initially tried ascent develop with vtk-m v2.1.0 and conduit v0.8.8.
    I was able to compile successfully, but the code hits a runtime error due to
    a missing vtk-m worklet library.
Without further ado, let’s open up a temporary directory and get started.
rm -rf tmp.build.deps
mkdir tmp.build.deps && cd tmp.build.deps
Constructive Solid Geometry (csg)
First I’ll install the dependencies for the csg-eb library.
export CSG_INSTALL_DIR=$HOME/packages/csg-eb-deps
mkdir -p $CSG_INSTALL_DIR
gmp
wget https://ftp.gnu.org/gnu/gmp/gmp-6.2.1.tar.xz
tar -xf gmp-6.2.1.tar.xz
pushd gmp-6.2.1
./configure --prefix=$CSG_INSTALL_DIR
make -j2 install
popd
Catch2
git clone --depth 1 --branch v2.13.7 https://github.com/catchorg/Catch2
pushd Catch2/
cmake -S . -B build -DCMAKE_INSTALL_PREFIX=$CSG_INSTALL_DIR
cd build/
make -j2 install
popd
mpfr
wget --no-check-certificate https://ftp.gnu.org/gnu/mpfr/mpfr-4.1.0.tar.xz
tar -xf mpfr-4.1.0.tar.xz
pushd mpfr-4.1.0/
./configure --with-gmp=$CSG_INSTALL_DIR --prefix=$CSG_INSTALL_DIR
make -j2 install
popd
CGAL
git clone --depth 1 --branch v5.3 https://github.com/CGAL/cgal
pushd cgal/
cmake -S . -B build -DCMAKE_INSTALL_PREFIX=$CSG_INSTALL_DIR -DCMAKE_BUILD_TYPE=Release
cd build/
make -j2 install
popd
PEGTL
git clone --branch 3.2.2 https://github.com/taocpp/PEGTL
pushd PEGTL/
cd build/
make -j2 install
popd
boost
wget https://archives.boost.io/release/1.83.0/source/boost_1_83_0.tar.gz
boost_1_83_0.tar.gz
tar -zxvf boost_1_83_0.tar.gz
pushd boost_1_83_0/
./bootstrap.sh
./b2 install --prefix=$CSG_INSTALL_DIR
popd
We are done building dependencies. I always super-build MFIX-Exa, so the csg-eb lib gets build right along with it. But, it’s probably not a bad idea to go ahead and build the standalone lib now too, just in case.
export CSG_LIB_DIR=$HOME/packages/csg-eb
mkdir -p $CSG_LIB_DIR
git clone https://mfix.netl.doe.gov/gitlab/exa/csg-eb.git
pushd csg-eb
mkdir build && cd build/
export Boost_INCLUDE_DIR="-I$CSG_INSTALL_DIR/include"
export CSG_DIR=$CSG_INSTALL_DIR
export CMAKE_PREFIX_PATH=$CMAKE_PREFIX_PATH:$CSG_DIR
cmake -DCMAKE_INSTALL_PREFIX=$CSG_LIB_DIR -DCMAKE_BUILD_TYPE=Release ../
make -j2 install
popd
linear solvers and multigrid methods
hypre
export HYPRE_INSTALL_DIR=$HOME/packages/hypre/v2.30.0
mkdir -p $HYPRE_INSTALL_DIR
git clone https://github.com/hypre-space/hypre.git
pushd hypre/src/
git checkout v2.30.0
./configure --prefix=$HYPRE_INSTALL_DIR --with-MPI
make -j2 install
popd
in situ visualization
conduit
export ASCENT_INSTALL_DIR=$HOME/packages/ascent/v0.9.0
mkdir -p $ASCENT_INSTALL_DIR
git clone --recursive https://github.com/LLNL/conduit.git
pushd conduit/
git checkout v0.8.6
cmake -S ../src -DCMAKE_INSTALL_PREFIX=$ASCENT_INSTALL_DIR -DCMAKE_BUILD_TYPE=Release -DENABLE_OPENMP=OFF -DENABLE_MPI=ON -DENABLE_CUDA=OFF
make -j2 install
popd
vtk-m
git clone --branch master https://gitlab.kitware.com/vtk/vtk-m.git
pushd vtk-m/
git checkout v1.9.0
cmake -S ../ -DCMAKE_INSTALL_PREFIX=$ASCENT_INSTALL_DIR -DVTKm_ENABLE_OPENMP=OFF -DVTKm_ENABLE_MPI=ON -DVTKm_ENABLE_CUDA=OFF -DVTKm_USE_64BIT_IDS=OFF -DVTKm_USE_DOUBLE_PRECISION=ON -DVTKm_USE_DEFAULT_TYPES_FOR_ASCENT=ON -DVTKm_NO_DEPRECATED_VIRTUAL=ON -DCMAKE_BUILD_TYPE=Release
make -j2 install
popd
ascent
git clone --recursive https://github.com/Alpine-DAV/ascent.git
pushd ascent
git checkout v0.9.0
cmake -S ../src -DCMAKE_INSTALL_PREFIX=$ASCENT_INSTALL_DIR -DCMAKE_BUILD_TYPE=Release -DCONDUIT_DIR=$ASCENT_INSTALL_DIR -DVTKM_DIR=$ASCENT_INSTALL_DIR -DENABLE_VTKH=ON -DENABLE_FORTRAN=OFF -DENABLE_PYTHON=OFF -DENABLE_DOCS=OFF -DBUILD_SHARED_LIBS=ON -DENABLE_GTEST=OFF -DENABLE_TESTS=OFF
make -j2 install
popd
MFIX-Exa
git clone https://mfix.netl.doe.gov/gitlab/exa/mfix.git
pushd mfix
git submodule init
git submodule update
mkdir build.deps && cd build.deps
cp <path-to-your-build-script> ./buildit.sh
./buildit.sh
where my buildit.sh looks like
#!/bin/bash -l
## set env
export CSG_DIR=$HOME/packages/csg-eb-deps
export Boost_INCLUDE_DIR="-I$CSG_DIR/include"
export HYPRE_DIR=$HOME/packages/hypre/v2.30.0
export HYPRE_ROOT=$HYPRE_DIR
export HYPRE_LIBRARIES=$HYPRE_DIR/lib
export HYPRE_INCLUDE_DIRS=$HYPRE_DIR/include
export ASCENT_DIR=$HOME/packages/ascent/v0.9.0
export CONDUIT_DIR=$ASCENT_DIR
export CMAKE_PREFIX_PATH=$CMAKE_PREFIX_PATH:$ASCENT_DIR/lib/cmake/ascent
export CMAKE_PREFIX_PATH=$CMAKE_PREFIX_PATH:$ASCENT_DIR/lib/cmake/conduit
## build mfix
cmake \
      -DMFIX_MPI=yes \
      -DMFIX_OMP=no \
      -DMFIX_GPU_BACKEND=NONE \
      -DMFIX_CSG=yes \
      -DMFIX_HYPRE=yes \
      -DAMReX_ASCENT=yes \
      -DAMReX_CONDUIT=yes \
      -DAMReX_TINY_PROFILE=yes \
      -DCMAKE_BUILD_TYPE=Release \
make -j 2
Running a job
I’ll use bench05 as a simple test of the executable.
First let’s make sure it runs “as-is”
cd ../benchmarks/05-cyl-fluidbed/Size0001/
ln -s ../../../build.deps/mfix
mpirun -np 1 ./mfix inputs
You should see a bunch of screen output that ends with AMReX (id) finalized.
Unfortunately, this doesn’t test any of the dependencies that we just built against.
Use your text editor of choice to modify the inputs file to
  1. use multiple grids:
    The grid size is set to the maximum, 1024 in each direction. And the
    entire domain size is just amr.n_cell = 20 5 5. Let’s set
    amr.max_grid_size_x = 10 so that the problem is decomposed onto two grids.
  2. use the csg library:
    Fortunately, there is already a csg file of the cylindrical EB, we just need
    to enable it. Just comment in the geometry_filename keyword and comment out,
    or delete, the amrex-native EB keywords,
    mfix.geometry_filename = "geometry.csg"
    #mfix.geometry = "cylinder"
    #cylinder.internal_flow = true
    #cylinder.radius = 0.00045
    #cylinder.height = -1.0
    #cylinder.direction = 0
    #cylinder.center    =  0.0020  0.0005   0.0005
  3. use the hypre linear solvers:
    This problem is simple, so amrex’s default bicg bottom solvers work fine, but
    let’s offload to hypre just to test the build,
    mac_proj.bottom_solver   =  hypre
    nodal_proj.bottom_solver   =  hypre
  4. use ascent visualization:
    Add these input keywords
    mfix.ascent_int     = 10
    ascent.actions     = "ascent_actions.yaml"
    and create a simple ascent pipeline named ascent_actions.yaml. Here’s a simple one to
    visualize the particles looks like
      action: "add_scenes"
      scenes:
        s1:
          plots:
            p1:
              type: "pseudocolor"
              field: "velz"
                radius: 50.0e-6
              min_value: -0.001
              max_value:  0.001
              color_table:
          renders:
            r1:
              image_width: 360
              image_height: 720
              image_prefix: "vis_p_velz_%06d"
              camera:
                position: [ 0.002,  0.0005,  0.0087]
                look_at:  [ 0.002,  0.0005,  0.0005]
                up: [1, 0, 0]
                zoom: 2.2
              bg_color: [ 1.0,  1.0,  1.0]
              fg_color: [ 0.0,  0.0,  0.0]
              render_bg: "true"
              shading: "enabled"
Now we’re ready to re-run. This time, use two processes and let’s pipe the std out
to a screen file,
mpirun -np 2 ./mfix inputs > screen.txt
In the output you should now be able to verify that you
  • :heavy_check_mark: ran in parallel by seeing MPI initialized with 2 MPI processes
  • :heavy_check_mark: used the csg-eb library by seeing mfix.geometry_filename: geometry.csg
  • :heavy_check_mark: if you enabled TinyProfile in the build, you should see several hypre routines being hit in the profiling at the end of the screen output, such as HypreIJIface::run_hypre_setup() and HypreIJIface::run_hypre_solve()
  • :heavy_check_mark: ran with ascent in situ visualization by seeing the printed png files, e.g.,
update 1 - to run the benchmark inputs with csg you now need to include the input mfix.geometry = "csg" as well.
I collected all the shell command into two bash shell script: one for downloading 3rdparty packages; one for building all the dependents libs.
How to use
./download.deps.sh
./build.deps.sh
Then build mfix
tar xvf mfix-24-06-tar.gz
cd mfix
./buildit.sh
Shell scripts
download.deps.sh:
#!/bin/bash
# Function to retry a command until it succeeds
retry() {
  local n=1
  local max=5
  local delay=5
  while true; do
    "$@" && break || {
      if [[ $n -lt $max ]]; then
        ((n++))
        echo "Command failed. Attempt $n/$max:"
        sleep $delay;
      else
        echo "The command has failed after $n attempts."
        return 1
      fi
  done
retry wget https://ftp.gnu.org/gnu/gmp/gmp-6.2.1.tar.xz
retry git clone --depth 1 --branch v2.13.7 https://github.com/catchorg/Catch2
retry wget --no-check-certificate https://ftp.gnu.org/gnu/mpfr/mpfr-4.1.0.tar.xz
retry git clone --depth 1 --branch v5.3 https://github.com/CGAL/cgal
retry git clone --branch 3.2.2 https://github.com/taocpp/PEGTL
retry wget https://boostorg.jfrog.io/artifactory/main/release/1.83.0/source/boost_1_83_0.tar.gz
retry git clone https://mfix.netl.doe.gov/gitlab/exa/csg-eb.git
retry git clone https://github.com/hypre-space/hypre.git
retry git clone --recursive https://github.com/LLNL/conduit.git
retry git clone --branch master https://gitlab.kitware.com/vtk/vtk-m.git
retry git clone --recursive https://github.com/Alpine-DAV/ascent.git
build.deps.sh:
#!/bin/bash
pushd gmp-6.2.1
make -j10 install
popd
pushd Catch2/
cd build/
make -j10 install
popd
pushd mpfr-4.1.0/
make -j10 install
popd
pushd cgal/
cd build/
make -j10 install
popd
pushd PEGTL/
cd build/
make -j10 install
popd
pushd boost_1_83_0/
./bootstrap.sh
popd
pushd csg-eb
make -j10 install
popd
pushd hypre/src/
make -j10 install
popd
pushd conduit/
git checkout v0.8.6
make -j10 install
popd
pushd vtk-m/
git checkout v1.9.0
make -j10 install
popd
pushd ascent
git checkout v0.9.0
make -j10 install
popd
buildit.sh
#!/bin/bash -l
## set env
mkdir build
cd build
## build mfix
cmake \
      -DMFIX_MPI=yes \
      -DMFIX_OMP=no \
      -DMFIX_CSG=yes \
      -DMFIX_HYPRE=yes \
make -j 10
Hi, Fullmer! Would you like to share some tips on how to enable gpu computionation for mfix-exa?
yes, but I don’t have a GPU card on my ubuntu machine, so I can’t give similar specific instructions. General build instructions are here and some machine-specific instructions are here. They are a little out of date and almost certainly can’t be c&p’d on your system, but it shows you how we compile for GPUs on several HPCs.
@basud0817 I forgot to follow up on this. You sent an email to the admin address, I don’t have access to that but someone dug it up and forwarded it to me. Were you able to build MFIX-Exa on your ubuntu machine following these instructions?
Hello Dr. Fullmer,
I have been busy setting up models on MFiX-DEM. Once I have some time I will certainly look into installing MFiX-EXA on my Ubuntu Linux.
I may open a new case and upload my MFiX-DEM file and results.
Thanks and Best Regards,
Sincerely,
Debashis
edit 1 - fixing the boost 1.83 version. The previous link didn’t work. Some newer versions work, possibly up to 1.87, but I just ran into problems with 1.88 so I’m fixing the link to the older 1.83. FYI the incompatibility is with CGAL v.5.3.x and if you update to the latest v6.0.1 version then that is incompatible with the csg-eb library. While I’m on the topic of version compatibility, may as well also note that there is also an issue with a recent hypre release. And vtk-m has recently been rebranded as Viskores, presumably breaking ascent/restricting it to the last vtk-m release, v2.3.0, until further notice.
