Hello, I just started learning MFIX. Can anyone share your views about if MFIX is able to solve conjugate heat transfer problem between fluidizing particles and metal thick walls of a fluidized bed with constant heat flux on one exterior side of the wall? Can MFIX generate user-defined finer meshes near the boundary of the wall?
MFiX cannot solve conjugate heat transfer, but it is being considered as new development for the future. You can only refine the mesh along a wall that is aligned with a major axis, using control points.
