Hi! I am using MFIX to simulate a gas-solid fluidized bed with the same geometry and solid properties but different gas velocities. So can I set a script or something else to let MFiX run a series of tasks one after another automatically? Instead of creating a new project every time only for changing the velocity of the gas inlet manually. Thank you.
My method is modifying the .mfx file with python and storing them in different folders. Then use bash script to access those folders and run the .mfx file in each folder.
Thank you! very helpful
You can do this with Nodeworks: Nodeworks - Multiphase Flow Science Group at NETL
