Can we do the flow simulation for the above attached geometry which has rotor and classifer inside the domain using mfix software. @cgw , @jeff.dietiker.
Probably not. If you have a moving geometry, the gas phase won’t see it.
Can’t we create a moving reference frame (MRF) region around the moving body( in this case around rotor) and do the flow simulation?
No, MRF is not supported.
