Hello, developers,
I want to simulate the high heat flux at the wall. When the constant heat flux is set to 40,000k/m it can be solved normally, but when I set it to 4000000k/m as shown in the figure two errors are prompted, “Unphysical field variables detected on one or more processes.” and “The MPI_Comm_f2c() function was called after MPI_FINALIZE was invoked. This is disallowed by the MPI standard. Your MPI job will now abort.” Is there anything wrong with this setting?
fluid_bed_counterflow_2023-03-09T051835.928221.zip (226.3 KB)
Thank you very much!
