Hi, I just want to solve the simple 2D model in TFM, but the residual is still too high with nearly 5*10^-3, and it can hardly reduce with the change of max-iteration and relaxation factor, the figure of residual is shown below. For supplemant, this model can be solved under lower gas velocity (0.3 m/s)
The settings in your attached files are different from the screenshots.
My suggestion is to run with ideal gas law for the fluid. If you really need to run as incompressible, increase the pressure and velocity iterations in the linear solver, and lower the relaxation factors. You cam also change the initial velocity (say lower y-velocity, and leave the pressure blank so it uses hydrostatic values).
