PLEASE HELP ME WITH THIS GEOMETRY. I NEED TO MAKE A CYLINDER INSIDE ANOTHER CYLINDER BUT I DONT WANT TO LOOSE THE WALLS OF THE SMALL CYLINDER.
IF I UNITE THEM , I LOOSE THE WALLS.
I can’t really see, but you need a gap between the small and large cylinder so there is a finite (not zero) thickness wall between the two. This gap needs to be larger than the grid spacing.
