I am running a simple example: the motion under local high pressure is normal during the calculation process of 10 atm. However, when I increase the pressure to 50 atm, the solver reports an error, and the error content is as follows:
MESSAGE from des\check_cell_movement.f:139
Error 1100: Particles detected in a ghost cell:
Particle 73 moved into cell with I index 152
X-Position: 0.3000 X-Velocity: 9.798
This is a fatal error. A particle output file (vtp) will be written
to aid debugging.
DHY.zip (1.6 MB)
