Hi, I would like to inject some particles into the fluid domain but failed.
I was wondering the mass flow rate and volume fraction of the gas and solid phase should follow a certain rule.
How i can control how many particles are injected to the domain?
ceshi_inflow.zip (29.3 MB)
If you specify a mass flow rate, then you must specify a non zero solids volume fraction, otherwise the inlet velocity cannot be computed.
