Hi
I got an error report saplates.zip (99.4 KB) id there is no CFD domain. All the cells are blocked.
There are several issues:
The STL normals are pointing in the wrong direction. This is a common issue, please see https://mfix.netl.doe.gov/doc/mfix/19.1.4/reference/faq.html#how-to-verify-flip-stl-file-facet-normals
There may be duplicate or small triangles in the STL, as indicated in the console:
STL file(s) successfully read.
Total number of facets read = 208
Number of valid facets = 144
Number of ignored facets = 64
You should aim for zero ignored facets. Either fix the STL file (recommended), or set the “facet angle tolerance” to zero in the Mesh>Mesher pane.
- The mesh is way too coarse to resolve the thin chevron plates. This may be a deal breaker since the mesh you will need to resolve the plates may be finer than the particle size.
Thank you very much.
