Hi
I want to test the RTD in two kinds of spout fluidized bed. This case(with two types of gas as tracer) works well when I take away the components in the spout region. If I turn off the species equation and only injects air, the case with the inner components also works well. However, i got this problem when i add the inner plates and two kinds of gas. I got this problem when the case run to 0.116 s. Thus, it makes it difficult for me to debug.
I do not know what is wrong with my case.
The mesh is not intersecting the STL file. I used a transform filter to scale the stl in the Z direction. This causes the STL to hang over the domain boundary, resulting in a better slice. Also, not all the facets were selected in the STL “wall” region. I also increased the number of cells in the Y direction. You need enough cells to resolve this small feature.
INFO check_data_30.f:373
Time = 0.15136E-03
Warning: The sum of mass fractions is not equal to one.
Statistics of sum of gas species mass fraction
Minimum sum of X_g= 0.99981
Maximum sum of X_g= 1.0000
Sum of X_g No of Cells Distribution
<0.9 0 0.0000
0.9 - 0.99 0 0.0000
0.99 - 0.999 0 0.0000
0.999 - 0.9999 812 0.44241E-01
0.9999 - 1.0001 17542 0.95576
1.0001 - 1.001 0 0.0000
1.001 - 1.01 0 0.0000
1.01 - 1.1 0 0.0000
>1.1 0 0.0000
which over time show that the mass fraction is not summing to 1 and getting worse as time increases:
Minimum sum of X_g= 0.99952
Minimum sum of X_g= 0.99864
Minimum sum of X_g= 0.99444
Minimum sum of X_g= 0.97929
Minimum sum of X_g= 0.95222
Minimum sum of X_g= 0.92742
Minimum sum of X_g= 0.90414
Please try with the attached. Your mesh is way too coarse and you don’t have side and front wall BCs defined. I ran with 80 cores, not sure how fast it would run in serial.
