Hello everyone:
I have a problem: when i use the SMP to speedup the case, there is an error 1000 comes out:
While, when I use the default solver, it is ok.
log.txt (580.0 KB)
geometry.stl (11.1 MB)
test_3.mfx (14.0 KB)
Hello everyone:
Congratulations, it looks like you found a bug in the SMP code.
A few questions:
Can you please upload the file geometry.stl.original ? If you use “Submit bug report” from the file menu, all needed files will automatically be included in the zip file.
How long did you have to wait until this error appeared?
Do you get different behavior if you change the number of threads?
Thanks,
OK,I have upload the files by Submit bug report.
Waiting for your good news!
I don’t see the zip file. “Submit bug report” creates the .zip but you still have to attach it here.
Sorry, I thought it was sent directly through the background.
Here it is.
test_3_2022-03-25T155117.921645.zip (46.6 MB)
I’m not seeing the NaN. I get a regular failure to converge (DT < DT_MIN) while running this, along with a large number of “Velocity exceeds limit” warnings:
Note that in the error popup, you can use left-right arrow keys to go through the messages, and TAB to go between the message categories.
Regarding the non-convergence, please see this section of the MFiX FAQ
What to do if a run does not converge
It also may help to search the forum for MAX_INLET_VEL_FAC . This issue has been discussed several times here, it often is due to extremely small cell sizes.
