Hi everyone,
I modified the tutorial 2-d pseudo spouted bed by adding chemical reaction and changing the inlet air to 300 centigrade. The solver is built successfully but an error showed:
ERROR check_data_30.f:670
Fatal Error: Unphysical field variables detected.
I J K
6 39 16 T_G = 250.0 <= 250.0
6 40 16 T_G = 250.0 <= 250.0
6 41 16 T_G = 250.0 <= 250.0
6 42 16 T_G = 250.0 <= 250.0
6 39 17 T_G = 250.0 <= 250.0
6 40 17 T_G = 250.0 <= 250.0
6 41 17 T_G = 250.0 <= 250.0
6 42 17 T_G = 250.0 <= 250.0
2 32 18 T_G = 250.0 <= 250.0
2 33 18 T_G = 250.0 <= 250.0
2 34 18 T_G = 250.0 <= 250.0
2 35 18 T_G = 250.0 <= 250.0
2 36 18 T_G = 250.0 <= 250.0
2 37 18 T_G = 250.0 <= 250.0
2 38 18 T_G = 250.0 <= 250.0
6 38 18 T_G = 250.0 <= 250.0
2 39 18 T_G = 250.0 <= 250.0
6 39 18 T_G = 250.0 <= 250.0
2 40 18 T_G = 250.0 <= 250.0
6 40 18 T_G = 250.0 <= 250.0
2 41 18 T_G = 250.0 <= 250.0
6 41 18 T_G = 250.0 <= 250.0
2 42 18 T_G = 250.0 <= 250.0
6 42 18 T_G = 250.0 <= 250.0
2 31 19 T_G = 250.0 <= 250.0
2 32 19 T_G = 250.0 <= 250.0
2 33 19 T_G = 250.0 <= 250.0
2 34 19 T_G = 250.0 <= 250.0
2 35 19 T_G = 250.0 <= 250.0
6 35 19 T_G = 250.0 <= 250.0
2 36 19 T_G = 250.0 <= 250.0
6 36 19 T_G = 250.0 <= 250.0
2 37 19 T_G = 250.0 <= 250.0
6 37 19 T_G = 250.0 <= 250.0
2 38 19 T_G = 250.0 <= 250.0
6 38 19 T_G = 250.0 <= 250.0
2 39 19 T_G = 250.0 <= 250.0
6 39 19 T_G = 250.0 <= 250.0
2 40 19 T_G = 250.0 <= 250.0
6 40 19 T_G = 250.0 <= 250.0
2 41 19 T_G = 250.0 <= 250.0
6 41 19 T_G = 250.0 <= 250.0
2 42 19 T_G = 250.0 <= 250.0
6 42 19 T_G = 250.0 <= 250.0
2 30 20 T_G = 250.0 <= 250.0
2 31 20 T_G = 250.0 <= 250.0
2 32 20 T_G = 250.0 <= 250.0
2 33 20 T_G = 250.0 <= 250.0
2 34 20 T_G = 250.0 <= 250.0
2 35 20 T_G = 250.0 <= 250.0
6 35 20 T_G = 250.0 <= 250.0
2 36 20 T_G = 250.0 <= 250.0
6 36 20 T_G = 250.0 <= 250.0
2 37 20 T_G = 250.0 <= 250.0
6 37 20 T_G = 250.0 <= 250.0
2 38 20 T_G = 250.0 <= 250.0
6 38 20 T_G = 250.0 <= 250.0
2 39 20 T_G = 250.0 <= 250.0
6 39 20 T_G = 250.0 <= 250.0
2 40 20 T_G = 250.0 <= 250.0
6 40 20 T_G = 250.0 <= 250.0
2 41 20 T_G = 250.0 <= 250.0
6 41 20 T_G = 250.0 <= 250.0
2 42 20 T_G = 250.0 <= 250.0
6 42 20 T_G = 250.0 <= 250.0
ERROR check_data_30.f:299
Unphysical field variables detected on one or more processes.
I then try a simple case that does not have chemical reaction and just heats the particle inside the spouted bed. This error appeared again.
I supposed that T_G is the temperature of gas and is lower than 250K but I do not understand why since the inlet temperature is 300 centigrade. Can anyone tell me what I was wrong? I really appreciate your help!
